95 CX o2 sensor help
Old Nov 22, 2008 | 09:03 PM
civicxxxb16a's Avatar
Default 95 CX o2 sensor help
Ok im getting a check engine light for an o2 sensor. Tried 2 others and still getting the light and yes i disconnect the battery to reset the ecu. I know it has something to do with the wiring because the check engine light doesnt go away even before I start the car. Its the one wire sensor and i even tried wiring it up right next to the ecu at pin D14 and still get the light. The thing is this car ran a chipped p28 ecu with a 4 wire o2 sensor and didnt have any problems now im running the stock p05 and wired it up for a 1 wire o2 and having problems. I even tried wiring it back to a 4 wire and pluged in my p28 and got the code right away before i start the car. I screwed something up and not sure what. Im almost 100% sure theres no fure for this now im stuck. Thanks for your help
Old Nov 22, 2008 | 11:51 PM
2wheelhunter's Avatar
i always thought just simply disconnecting the battery never resets the battery but you must touch both terminals together the make it reset
Old Nov 23, 2008 | 09:50 AM
CivicSpoon's Avatar
WHAT?! I hope to god you're joking.
To the OP, sorry I have no idea why it wouldn't work, it sounds like you have it wired up properly.
Old Nov 23, 2008 | 11:06 AM
i had a CEL code that wouldnt go away unless i touched both ends together... i didnt meen the actual battery terminals but the fittings that go on them.. my bad
Old Nov 28, 2008 | 05:38 PM
Well I was working on the car today and tried your suggestions and still having the same problem. Tried couple differnt o2 sensors and ecus and still getting the code right away.
yeedub
Apr 13, 2013 10:35 PM
si0385.
Sep 10, 2006 11:49 AM
hondaracing1
Mar 10, 2005 04:51 PM
