Cant connect to com port... Crome
Old Nov 22, 2008 | 08:44 PM
94EGZI's Avatar
Default Cant connect to com port... Crome
Ok i just got my ecu in today put it in and connected the 4 pin header and connected the cord to the usb blah blah. well i hooked it all up and says incorrect com port.. so i went to device manager and saw nothing about com port/ltp or something. So right when i plug the usb cable into my laptop a install hardware screen pops up. Sooo what do i do from here? i got 4 usb ports on my laptop and tryed up to com port 6 on the freelog and not of them worked. when i search for the com ports in the device manager its doesnt have them. has usb bus controllers is it? when i connect the usb cable ?Other Devices pops up in the device manager.. so what do i need to do? if i only got 4 usb ports it shouldnt go higher than comp port 4 right? lol sorry for the long random questions i just cant find out what to do
Sorry for the pics my camera sucks and its dark outside lol
Old Nov 22, 2008 | 08:58 PM
94EGZI's Avatar
for alittle more info if it helps..
using crome free and freelog.. can i still be able to log even though i got the free crome version?
Old Nov 23, 2008 | 04:34 AM
94EGZI's Avatar
Alright after looking into it a bit further last night i came across that i needed to install a specific usb driver for this. so i did so and still cant connect to the ECU through RTP on crome?? it connects to the port and get connect but cant connect to ecu for RTP. do i need crome pro for this? anyway i can pull up the data from my ecu without logging through crome? I tryed freelog and cant get any of it working.. rpms dont work mph and bat volt is way off and 75% of the things dont work in live data. does it matter which way the plug is plugged into the 4 pin header in the ecu? dont know if that would make a difference
Heres some pics
Old Nov 23, 2008 | 06:17 AM
mtber's Avatar
Make sure the quick datalog + rtp plugin is installed on the binary you are using.
Read the tutorial on: http://www.moates.net/zips/crome/Tun...ME%20v1.03.pdf
Old Nov 23, 2008 | 07:23 AM
94EGZI's Avatar
I was just wondering if i can open up the base map thats on the ecu already and tune off that one? i dont really wanna start from scratch when this one is just alittle off of my liking.. when i try to goto plugins i cant add it because i dont have a rom opened
few pics
Old Nov 23, 2008 | 10:34 AM
mtber's Avatar
1. Open the co-existing binary you want to tune on.
2. Add the plug-ins required to datalog.
3. Make sure j12 is removed from your ecu, if not remove it using a small pair of snippers.
4. Try datalogging & follow the guide on http://www.moates.net/zips/crome/Tun...ME%20v1.03.pdf
HondaKing90
Audio / Security / Video
Aug 1, 2010 04:20 AM
AlphaQup
Nov 7, 2006 09:05 PM
Ls_dx
Jul 20, 2006 08:52 AM
revhi
Feb 16, 2006 01:16 PM
