Help - removing side moldings
Old Nov 22, 2008 | 05:59 PM
dopamean's Avatar
Icon3 Help - removing side moldings
flathead screwdriver? pop out clips?
don't wanna break anything, just wanna paint and reattach
please help.
also comment on the stock side skirts if you know how to remove those
thanks
Old Nov 22, 2008 | 06:05 PM
z6hatchboy's Avatar
Side moldings- take needle nose pliers and just pop the clips, the door molding have a nut on the end of it (towards back of car), and its a lot easier to get to the last one (towards front of car) if you take the speaker out
Old Nov 22, 2008 | 06:10 PM
kp's Avatar
kp
If it's the same as my EK, then the door moldings are a biatch to get off. You have to get to them from inside the car. They're held on by square plastic clips that actually expand and hold themselves in when you install them. My ek moldings were also attached with crazy sticky adhesive. Believe me when I say that you'll be much happier just taping your car off and painting them on the car.
The side skirt moldings on the other hand are incredibly easy to remove. First, remove the screws behind the front wheel and the screws under the car that actually hold the molding on. There may also be some at the rear wheel too but I don't think so. Once you're certain all of the screws are out, simple slide the molding horizontally to unhook it from the plastic clips. Once the molding is off, turn the clips 45 degrees and pull them out. To reinstall, put all the clips back on the side molding and clip it on. Simple!
Old Nov 22, 2008 | 06:22 PM
z6hatchboy's Avatar
Forgot that haha, you have to remove the door panels and other inside panels to get to the clips. Not hard just time consuming though. well worth it for a quality paint job
Old Nov 23, 2008 | 08:45 AM
dopamean's Avatar
got it. thanks for the help guys.
Old Nov 23, 2008 | 11:48 AM
teamworxek9's Avatar
the door ones werent so bad but the rear ones earned me some cuts.
oO-SIX-Oo
May 21, 2010 03:53 AM
IT'S ME DAVID
11
Aug 18, 2009 06:40 AM
FRKWOO
Dec 26, 2008 12:28 AM
Protoss
Mar 9, 2006 04:42 PM
