Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
RSX-S Aftermarket shocks on Civic SI
Old Nov 22, 2008 | 12:27 PM
cretinx's Avatar
Default RSX-S Aftermarket shocks on Civic SI
I autocross and I'd like to get some Koni Yellows - unfortunately Koni doesn't make the full set for my 08 SI - just front inserts and rears.
Are the RSX-S aftermarket shocks compatible and interchangeable with my 08 SI Sedan's? I believe the suspension is pretty much the same . . . . ?
Old Nov 23, 2008 | 11:24 AM
cretinx's Avatar
bump
Old Nov 23, 2008 | 01:54 PM
pd0019's Avatar
no they are not. rears are completely different. fronts maybe.
if you're autocrossing, buying a rsx setup may hurt you more b/c you are buying a setup not designed for your car.
Old Nov 23, 2008 | 02:12 PM
Kidnkorner's Avatar
I thought I replied to this already.
None will work, not even the fronts.
What class do you run in, If i'm not mistaken you have to run the stock struts but can change the springs. If you can get the HFP or the Mugen units you may be able to run them because they are stock for that chassis.
RSX
Civic
Old Nov 23, 2008 | 02:46 PM
cretinx's Avatar
RSX
Civic
G-Stock
allowed to run aftermarket shocks as they are a "wear and tear" item that can be replaced.
Not allowed to run the HFP setup because they are not factory installed equipment, they're a dealer installed accessory.
Old Nov 23, 2008 | 02:47 PM
cretinx's Avatar
struts not shocks
god I hate these macphersons - max negative camber in the front is a massive -0.8, that's with two crash bolts.
Old Nov 23, 2008 | 02:59 PM
Kidnkorner's Avatar
Originally Posted by cretinx
G-Stock
Well then if you are allowed to run aftermarket then you can run HFP, right?
If the class allows factory installed parts then mugens can be used.
Old Nov 24, 2008 | 09:18 AM
cretinx's Avatar
I can use the HFP struts, but not the springs - springs must be stock. I haven't been able to find the HFP struts anywhere.
If I were to run a single Mugen part then I would have to convert the entire car over to the Mugen setup. Thems the rules.
Old Nov 25, 2008 | 03:27 PM
ROCKSTAR RX8's Avatar
SKUNK2 makes Sport Shocks for FG2 here's the Part No. 541-05-1250
Old Nov 25, 2008 | 04:02 PM
Kidnkorner's Avatar
I told him that in a pm, use the coupon code "htholiday" at www.allversionperformance.com all skunk2 suspension is on sale.
NEO_FOLLOWER2
Sep 26, 2012 07:41 PM
djviet2000
Feb 1, 2011 06:28 AM
02whiteDC5
Aug 11, 2007 06:27 AM
SoSoJeff
Sep 27, 2003 10:50 AM
teo409
Jul 15, 2003 01:09 AM
