Jdm D15b Vtec Swap: NEED HELP!
Old Nov 22, 2008 | 11:48 AM
IHEARTMYHONDA91's Avatar
Icon2 Jdm D15b Vtec Swap: NEED HELP!
i just got my d15b vtec swap all done in my '89 crx dx.
when i went to start the car it just cranks and cranks and cranks.
im running a p28 ecu, rywire ecu jumper harness with vtec sub harness, and a nigaphan dpfi-mpfi engine harness
the only code im throwing is a code 41 primary oxygen sensor heater, and im guessing its only because i dont have my o2 sensor hooked up.
does anyone have any suggestions?
Old Nov 22, 2008 | 07:01 PM
dabrat8614's Avatar
tranny ground, valve cover ground, thermostat ground. sand em, try again. gl
Old Nov 22, 2008 | 07:24 PM
NATEDEEZY's Avatar
check for spark and fuel ........and i just did a swap in my dpfi 91 hatch and i had to switch a couple of wires at the ecu harnes on the car side ...did you have to ??????
Old Nov 22, 2008 | 07:51 PM
ok got the car to fire up!
plugged the o2 sensor in so no more code 41
only code its throwing now is a 14 cause my iacv is broken.
but thanks guys for the input... Does anyone happen to know what kinda radiator i can run in my crx turns out mines cracked pretty bad
Old Nov 22, 2008 | 08:27 PM
NATEDEEZY's Avatar
should be able to use a stock 88 - 91 ef (civic, or crx rad), dont do da (integra) because they use b series hoses
PredatorSi
May 10, 2018 09:08 PM
neofreak
Apr 18, 2009 11:52 PM
IHEARTMYHONDA91
Mar 1, 2008 12:17 PM
jccrxtuner916
13
Jan 26, 2006 07:07 PM
mrbsponge
Mar 24, 2004 03:54 PM
