Easy door checker / indent rod question
Old Nov 22, 2008 | 02:50 AM
paulhsu's Avatar
Default Easy door checker / indent rod question *diagram pic
Long time lurker, but I can't find anyone else asking about this. My 1997 door checker / indent is making a very harsh grinding noise when the door is opened and closed. I tried white lithium grease but it didn't help at all.
part #12 is the area I am talking about
If I remove the 2 10mm bolts ( and the pin connecting the indent on the frame body #16) will the entire assembly pull out for inspection/replacement or do I have to remove the door panel and detach something inside the actual door?
Old Nov 22, 2008 | 03:30 AM
P_Adams's Avatar
From the illustration, you'll be dealing with #'s 12,16 and 27
Door Stop assembly
Door Stop attachment pin
Door Stop retainer screws (2)
If I remember correctly, it's no more than opening the door full, remove the pin, removing two screws and it ends up in your hand.
P
MechEng
Jan 30, 2012 02:03 PM
todd.ludwig
May 1, 2006 02:27 AM
garrybloom
Jan 24, 2005 12:42 PM
Kenshou Motorsports
Dec 30, 2004 12:41 AM
