Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Can't get my GroundControls perches to unlock so I can adjust the height.
Old Jul 31, 2002 | 10:36 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Can't get my GroundControls perches to unlock so I can adjust the height.
I wanted to adjust my hieght on my GroundControls but theres that part that you need a HEX wrench to loosen the perch right? Get me so far?? Then after loosening it, you use the gold wrench to turn the PERCH up or down the coil. Know what I'm talking about? Well, I coudn't get that damn thingy loosen, it was on too tight and ended up rounding my hex wrench. I can't adjust my damn hieght now, what do I do? I'm going to buy another hex thingy tomarrow.
Old Jul 31, 2002 | 10:41 PM
JeffS's Avatar
Default Re: Can't get my GroundControls perches to unlock so I can adjust the height. (Snafu-Si)
Make sure you're using the right size allen wrench. It's an SAE size (can't remember what right now), not metric. If that doesn't work, you could try a star driver. If you can find the right size, it will often help remove an allen-head bolt that's starting to round off.
You might as well round up a replacement bolt while you're at it. If you've damaged it and do manage to get it out, the last thing you want to do is put it back in. 'Cause you might not be so lucky next time.
Old Jul 31, 2002 | 11:25 PM
Tyson's Avatar
once you strip a cap screw, its toast. gotta get a screw extractor. try the sears version or an easy out. always use the correct driver size.
Old Aug 1, 2002 | 03:00 AM
Geezer's Avatar
Over the years I've learned that the very first thing you do when working on the suspension is hit the bolts/nuts/screws you want to remove with Power-lube, Liquid Wrench, WD-40, etc. and let it soak in for an hour. Overnight is better.
Old Aug 1, 2002 | 08:23 AM
manveer's Avatar
You stripped the key? The one they give with the coilovers is pretty damn solid and fits perfectly. Just make sure you're not turning it when it's half-way in or something...
Old Aug 1, 2002 | 11:50 AM
Snafu-Si's Avatar
Default Re: Can't get my GroundControls perches to unlock so I can adjust the height. (zyg)
Thanks for alll the info guys, I appreciate it. I'm going to get a new Hex wrench and buy a 3/16 hex bolt while I'm at it. Dont want to go through all again. Hey, does anybody know what size the hex bolt is???
Old Aug 1, 2002 | 03:23 PM
Snafu-Si's Avatar
Well, I bought a 3/16's wrench and some liquid wrench stuff. The guy swears by it soooo.. I also boutgh some"MECHANICS" gloves. I'm goign to use them for driving though. AFter putting them on, Ididnt' feel like I wanted to get grease and oil all over them. They feel like driving gloves sooo..
Old Aug 1, 2002 | 03:36 PM
Shingoblade-GSR's Avatar
I had the same problem...wrench didn't fit
However, the front coils were loose already and I could adjust it up and down
what car do you have? Maybe it's a different system on the integra...because my fronts are loose as all hell
I couldn't get the rears to adjust though...they were definitely locked...actually I had trouble reaching past the wheels to get to the coil.
Shingo
Old Aug 1, 2002 | 06:06 PM
jasyatz's Avatar
Default Re: Can't get my GroundControls perches to unlock so I can adjust the height. (Shingoblade-GSR)
..Try this...
I rounded off a hex wrench on a frozen GC perch and said what the hell, let me try this...
Got a 3/8" drive T20 torx socket and 12" extension on a 3/8" drive ratchet. Put the socket on the extension and tap the extension with a hammer to seat the socket into the hex bolt (just enough to bottom out the socket in the base of the bolt), turn the bolt loose..
Works on the corners, not on the flats...Now I carry the T20 setup wherever I got Just in case...
Hope it works for you...
Jeff
Old Aug 2, 2002 | 02:01 AM
Snafu-Si's Avatar
Default Re: Can't get my GroundControls perches to unlock so I can adjust the height. (jasyatz)
I've rounded the little bolt too much for me to get a good amount of turn with my hex wrench. THis sucks. I don't konw what to do. I'm going to hve my friend help me think up a idea, but really, I have no idea what the **** to do.
I guess i can try that Torx thingy that you mentioned. Ahhhh.. this sucks ***.
Old Aug 3, 2002 | 11:31 AM
Snafu-Si's Avatar
What is a screw extractor? I've never heard of it. I might have to get one of thsoe. It doesn't look too good right now as the bolt just dosen't want to come out at all.
Old Aug 3, 2002 | 05:48 PM
jasyatz's Avatar
Try the torx bit, works in the corners, not on the flats. Unless you used and oversized hex wrench, the torx will fit right in...
You can also try a T25 if it's really rounded off, just need to tap it in a little harder...
Trust me it works...We almost gave up on a 2 hour alignment (I'm a perfectionist) on a friends car when his left front froze and couldn't get any camber adjustment, tried it on a whime (instead of giving up) and worked like a charm..Even after rounding off the bolt with the supplied "useless" hex wrench....
Jeff
arielb1
Apr 18, 2016 02:38 PM
b16greenmachine
27
Sep 17, 2007 08:44 AM
LawlessOne
Jun 18, 2006 01:41 PM
Sephro
Apr 26, 2004 07:34 AM
dunkd
Feb 16, 2004 09:54 AM
