What size throttle body am I suppose to use 66-74?
hi guys, I have a 91 crx si sohc zc, headers, pulley, ground kit CAI cam gear complete exhaust and now a blox intake manifold. Though I don't know what size throttle body I'm suppose to run, I know edelbrock makes 65 mm carb legal ones. But I've read of people running 74 mm ones with no issues. This is a weekend warrior, autox car, so I'd like some decent gas mileage and as much HP as possible. I'm not sure if the throttle body affects mpg, but anyi nfo you guys might have, please comment. I'm leaning for a blox throttle body, either 66 68 or 70 mm. Thanks guys
you should get a t body that matches the port of your intake plenum because it will create less air turbulence. if you are not running an aftermarket intake mani you can have your stock one port matched and screet honed for better flow.
