Roaring idle + Overheating in 40*F Help!
Old Nov 21, 2008 | 09:25 PM
LeArN2LiVe's Avatar
Default Roaring idle + Overheating in 40*F Help!
Never had this problem happen before until about an hour ago. Got into my car and noticed the idle at 3000RPM for about 5 minutes then it would constantly jump from 1000RPM to 3000RPM. The car would, in about another 5 minutes, overheat past the gauge. After I parked, I also noticed all my coolant on the ground.
The strange thing though, while it would overheat I tried to turn the heater on but it would blow ice cold even though my car doesn't have A/C and the heat was all the way up.
Any suggestions?
Old Nov 21, 2008 | 09:31 PM
SleepRdc2's Avatar
Do you have antifreeze? Replace your thermostat if your lower hose doesn't get warm.
Old Nov 21, 2008 | 09:32 PM
LeArN2LiVe's Avatar
Antifreeze is spilt all over the ground. Can the tstat go bad randomly though? It was perfect last night.
Old Nov 22, 2008 | 06:18 AM
deftonerider's Avatar
check your coolant you might have air in the system, bleed the system
Old Nov 22, 2008 | 11:33 AM
VegasInvasion's Avatar
I'm Huge In Japan
Your thermostat can go bad at any time. But the heater would be hot even if your thermostat was bad, which indicates you have no coolant, and... well that's your problem. Find the leak, fix it, and fill it back up with coolant.
Just make sure to bleed out the bubbles in the coolant through the bleeder valve after you fix it.
Old Nov 22, 2008 | 12:08 PM
AWD Terror's Avatar
Correct. If your temp gauge is high, your heater should blow hot. There is only two reason why it would not that I can think of:
1) There is air in the heater core.
2) The heater core is clogged.
SpEeDyX
Jul 5, 2009 10:59 AM
blue89hatch
Aug 12, 2008 07:57 AM
`chrisb
May 18, 2008 04:21 PM
homeskillet
Dec 24, 2004 09:22 PM
xSCTYGx
Apr 30, 2004 10:31 PM
