A little help w/ wheel bearings...
Im putting ARP extended wheel studs in my hatch, and i already have the rears done. but for the front i decided to pound out the spindles/bearings so i could put the wheel studs in befor i go to a shop to get new bearings and have them pressed in. well this is what i have now...
as you can see parts of the wheel bearing are still on each part...
my question is, can these peices of the old bearing be removed easily with a press? or any ideas? im tryin to stay away from buying new spindles. thanks
When i removed my spindles for bearing replacement, I just brought the new studs with me and before the guy put in the new bearing he installed the studs free. They are so easy to install they prob won't charge you. So if you didn't do the other one yet, just leave it. Too much work, when you see the press remove that in a second you'll see its not worth your time!
on my back spindles w/ the new studs i put little tack welds on the back of each one... did they do that for you? and how much was it?
one more question... do i have to replace the ring clips? the one from this hub got just a little tweaked removing it
do i have to do that too or can a shop do it for me?
91integra_rubio
Apr 28, 2009 11:18 PM
