Problems with ls vtec in 89 crx si!!!
I have recently put an LS vtec engine into my crx. I did a wire tuck and also got rid of my resitor box for my injectors. While finishing my wire tuck, I realized that the plug that feeds all of my injectors and also looks like it has a temp sensor in it has no mating plug to go to. I do not know where it could have gone. The plug is a female eight pin white round plug that goes to my injectors and like i said, also has a temp sens. in it as well. I know it needs to go to the drivers side where the resistor box was, but the plug is nowhere to be found and i didn't cut anything out. I just wired all of the proper Wires together for the injectors and used the proper inpedence injectors to eliminate the resistor box. PLEASE HELP or direct me to pictures of the harness. Oh and my fuel pump is not turning on, but the main relay is clicking. THANKS
