a/c left open for an hour?
Old Jul 31, 2002 | 10:07 PM
Eg6_JDM's Avatar
Default a/c left open for an hour?
i was told that if a/c compressor was left open for an hour you would have to change something?
is this true.....
Old Aug 1, 2002 | 02:19 AM
kinesistech's Avatar
Default Re: a/c left open for an hour? (Eg6_JDM)
Reciever dryer or accumulator depending on the system. They're both the same. Its the little can behind the headlight. If you pull a vaccum on it for a long time you can reuse it but replacing it is easier and cheaper if you dont own the $400 pump to do it.
To charge the system you will need to produce a vaccum anyway but only for 10 minutes.
If you disconnect the a/c system, plug the hoses with something. Moisture plus a/c refrigerant equals acid. Bad for the rest of the system. Usually nothing to worry about, but it can happen.
Old Aug 1, 2002 | 12:19 PM
Chiovnidca's Avatar
An hour shouldn't hurt it. Just vac it down real good before charging.
Old Aug 1, 2002 | 06:28 PM
Cory man's Avatar
Default Re: a/c left open for an hour? (Chiovnidca)
the beater rex had the system open for a few yrs. Filled it full of r134a and some nice new comp oil and it blows nice and cold. my .02.
wheelgarage
Jul 18, 2010 08:30 PM
T:rex
Jul 14, 2009 08:56 PM
JDM_Andrew
Sep 17, 2008 06:53 AM
Boostage
Jul 24, 2006 09:25 AM
B18C1 '96 Coupe
May 3, 2003 02:13 PM
