Cylinder 1 and 2 are not firering, HELP!!!
I just built an obd1 Poor man type r, now i have fuel and i have Spark, but Cylender 1 and 2 are not firering. I changed the Injector, it still doing the same., My next thing is to change the ECU, and if not check the Distributor. What ya think? Any help would be appreciated, thanks.
Find out if you have spark at those two cylinders...
Find out if you have injector pulse to those two cylinders... Used a niod light set or a test light.
If you have both of the above, recheck your plug wires/ are they on right? Double check.
spark plugs are new and so is the wires, so ill try the next ecu, my buddies ecu. If that dont work, ill go into the ignition, a nd pretty much what ya posted it, thank you. Also compression test was done and is good, thank god.
i just check it. Its good. Im waiting for my freinds ECU, and then im changing the Distrobutor, If anybody has anymore ideas Please let me know and thank you for your replys
Don't just thorw parts at it, that is what make it expensive.
the firing order is good, TDC is good, i have already checked the the ECU, its not it, now im going into the distributor. Im using my buddies tomorrow. hopefully thats it. Thank ya so much for ya help. If anyone has any more ideas, they are very welcome. thank ya again
If you get spark and fuel then by default it should fire. Fuel + source of ignition= fire. You arent getting one or the other to those cylinders. I would check the distributor.
