What removes carbon in manifold?
Old Nov 21, 2008 | 05:23 PM
alscrx's Avatar
Icon2 What removes carbon in manifold?
I got an intake manifold that i wanna clean before installing. I see alot of black soot or carbon inside the runners. I tried throttle body cleaner and it did nothing. I also tried degreaser and the black is still there,
I know there is something that will breakdown this crap. What did you guys use?
Old Nov 21, 2008 | 05:40 PM
acmoc's Avatar
I heard that seafoam stuff, really I don't know what else, that stuff looks pretty stuck on their. maybe paint stripper and a metal brush
Old Nov 21, 2008 | 06:34 PM
alscrx's Avatar
will seafoam work while its off the car??
Old Nov 21, 2008 | 06:39 PM
Crx Jimmy's Avatar
use gasoline, gets it right out, soak a rag and pull it through the runners.
Old Nov 21, 2008 | 06:43 PM
alscrx's Avatar
Really??? Ok gonna try it!
Old Nov 21, 2008 | 06:44 PM
alscrx's Avatar
What will get rid of the gasoline residue and smell afterwards??
Old Nov 21, 2008 | 06:50 PM
soodominican's Avatar
DUDE SEAFOAM THE **** OUTTA IT, seriously. take the pcv valve off and spray the seafoam in there while holding ur throttle to 2K rpm and empty the ****ing can. it'll run like **** for 15 minutes but she'll run so smooth afterwards. btw the cars gonna look like its 1000hp mustang burning out while the ur sprayin the seafoam. it works tho.. my boys car even stopped surging WOW!
Old Nov 21, 2008 | 06:58 PM
crisco_inferno's Avatar
The gasoline should just evaporate.
Old Nov 21, 2008 | 07:05 PM
H9Omega's Avatar
Spray it down with carb cleaner and let it work itself and rinse.
Old Nov 21, 2008 | 07:09 PM
alscrx's Avatar
carb cleaner doesn't work, i tried!
Old Nov 21, 2008 | 07:13 PM
H9Omega's Avatar
Ouch! You must have some extremely serious build-up there!
Old Nov 21, 2008 | 07:52 PM
radex7's Avatar
Default clean manifold?
hey, I just wanted to include my experience here as well. I spent $15.00 at the engine shop (it is roughly 3 cans of Sea Foam - right?). They dunked my manifold for less then an huor in parts washer and this is what I got back:
Personally I like using concentrated Simple Green. Smells better, not as toxic to you, and apparently close to be biodegradable. I soaked my pistons in simple green for a while and it did a really nice job I think. Cap was not soaked - you can tell the difference, right?
Old Nov 21, 2008 | 07:59 PM
Crx Jimmy's Avatar
the gas works great, if there are any stubborn spots use some gas with a tooth brush to loosen. just use some brakleen to wash it out after the gas evaporates.
Old Nov 22, 2008 | 05:45 AM
alscrx's Avatar
WOW, that manifold looks clean inside. Well worth 15 bucks!
I don't think i have an engine shop near me but i have look into it. Looks like i'll be trying the gas technique then simple green it to rid the smell.
Old Nov 22, 2008 | 06:11 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
I have fund nothing that works as well or as fast as spray paint remover.
As long as you use it on bare metal ( no powder coatings, paint, silk screens) the carbon build up just melts away.
put the part on the floor and use a hose to rinse away the stripper.
It might take 2 applications, but you don't even have to touch the part.
Old Nov 22, 2008 | 11:38 AM
alscrx's Avatar
You mean stripper like aircraft stripper?
What brand you use?
Old Nov 22, 2008 | 02:52 PM
4DRmafia's Avatar
I used air craft paint stripper. It works just fine. I let it sit for about 15- 30 mins and rinse it off with water and it looks clean and new! It actually made my outside of the intake looks new too.
Old Nov 22, 2008 | 04:14 PM
1badascivic's Avatar
seafoam and let it sit for like 5 mins and spray it out will look new
Old Nov 22, 2008 | 05:25 PM
alscrx's Avatar
OK, thanks guys!
Old Nov 22, 2008 | 05:41 PM
specialized108's Avatar
simple green or purple power and an old tooth brush works pretty awesom
Old Dec 5, 2008 | 02:28 PM
alscrx's Avatar
WOW, nothing worked like the aircraft remover. I used the gel one in a 32oz can cause it was on sale. I spread it in the runners and you can see the black carbon liquify. Now the manifold looks like new inside.
Old Dec 5, 2008 | 07:43 PM
4DRmafia's Avatar
Told ya so! I used the spray can one, but same thing anyhow. I did my throttle body and everything else and came out like new.
UrbanDiplomat
Mar 15, 2013 06:22 PM
kixcrx
Jan 10, 2007 04:40 PM
SOHCD16y8
Apr 3, 2005 07:46 PM
SOHCMAN
Jun 29, 2003 03:40 PM
mipawi
Dec 22, 2002 01:05 PM
