93 sedan swapped d16a6
Old Nov 21, 2008 | 01:39 PM
0ne-Cam's Avatar
Default 93 sedan swapped d16a6
as it shows above i did a swap from d15b7 to d16a6.. i was told that my fast idle valve had gone bad so i replaced the whole throttle body with the fiv. it still idles like crap. going from 1.5k rpm to 3, idling up and down. any suggestions?
Old Nov 21, 2008 | 01:42 PM
waynecoSI's Avatar
clean your throttle plate, check your vacuum lines, make sure everything is plugged in. Check your coolant level. low coolant will cause idle to surge.
Old Nov 21, 2008 | 01:46 PM
94EG8's Avatar
Seagull Management
Yeah, I'd say either the IACV is bad or dirty, or the cooling system needs to be bled. Also possible that the IAT and IACV connectors got switched during the swap, certainly wouldn't be the first time i've seen it happen, you should have a CEL for that last one though.
Old Nov 21, 2008 | 01:58 PM
0ne-Cam's Avatar
theres no CEL's. and also theres no coolant in the radiator so that could be the reason its idling bad right?
Old Nov 21, 2008 | 02:01 PM
94EG8's Avatar
Seagull Management
Yes. add coolant and bleed the cooling system before you go any further.
chope045
Oct 24, 2011 04:12 PM
RiceBurninCX
Jan 24, 2008 02:02 PM
dem0nk1d
14
Mar 22, 2006 05:57 PM
Matt00
Nov 3, 2005 06:01 AM
Ian in Oz
Jun 4, 2003 10:21 AM
