rear disc brake swap
Old Nov 21, 2008 | 10:51 AM
racingcrx's Avatar
Default rear disc brake swap
i've searched and found nothing. so i might do a write up on how to install the inetgra disc brakes onto a crx. i was wondering what brake cable to use when i do this swap? i know i'll have to change to porportioning(sp?) valve, brake m/c and other stuff.
Old Nov 21, 2008 | 10:55 AM
Ermil's Avatar
There is PLENTY of info in the FAQ's and search. I just did it, that's what I searched. Hell, search my screen name and you'll find my thread with lots of info.
Old Nov 21, 2008 | 01:20 PM
uberEFtuner's Avatar
I used the whole integra setup cables and all on my 91 Civic hatch.
Old Nov 21, 2008 | 01:30 PM
mrflak0's Avatar
well if you doin the conversion then you could use rear brake cables for a crx because the si had rear disc
Old Nov 21, 2008 | 02:09 PM
EL Vap133's Avatar
The 90-91 CRX Si to be exact (rear disc brakes).
Old Nov 21, 2008 | 09:17 PM
racingcrx's Avatar
so i should buy 90-91 SI brake cables???
Old Nov 22, 2008 | 09:56 AM
EJ1_Sleeper's Avatar
i think you might need the CRX si rear brake cables for it to work, unless you want to adjust the hell out of the DA cables to work. I know the DA cables work on the hatches.
tried to look up parts numbers and the drum lines for the hatches are the only one that shows up, the CRX si has the rear disk cable tho. to be safe just go with the CRX si's if your buying it new.
Old Nov 22, 2008 | 01:06 PM
racingcrx's Avatar
thank you for the info guys. should i do a write up?? including plenty of pics. just curious
Old Nov 22, 2008 | 03:43 PM
EFRue57's Avatar
if you want to then go ahead, but this topic has been covered lots of times, and it is in the FAQ's. here's the link to the actual thread
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rear-disk-brake-conversion-w-pics-1916212/
ZCHondaCRX91
Dec 4, 2011 03:03 AM
bradennicely
Oct 12, 2009 06:10 PM
CRX 2.0V-T
Oct 10, 2006 07:25 AM
WVTURBOCRX
Sep 20, 2005 08:43 PM
BAZ
28
Sep 21, 2003 10:24 AM
