Oil Change special
Old Nov 21, 2008 | 10:44 AM
Devon M's Avatar
Default Oil Change special
I am getting ready to do an oil change and I am not sure of what brand to use. I searched the FAQ and archives but there is not anything on user preference. So I was curious what are you guys useing for filters and oil? I plan to add this to the FAQ in the oil section.
Old Nov 21, 2008 | 10:48 AM
R.Kelley's Avatar
honda filter and syntec 5-40....i also burn alot of oil
Old Nov 21, 2008 | 10:56 AM
Jay D. Em's Avatar
napa gold filter and castrol syntec 0-30 euro formula
Old Nov 21, 2008 | 11:22 AM
01typeR152's Avatar
I use Hamp oil filter with Enos oil syntec!
Old Nov 21, 2008 | 12:21 PM
clem kevin's Avatar
I've been using royal purple for street use. I also use K&N filters. When i go to the track i put in Amsoil 10w-40 though.
Old Nov 21, 2008 | 01:24 PM
00TypeR1071's Avatar
I use 5W30 Mobil 1 Syntetic oil with OEM Honda S2000 oil filter.
Old Nov 21, 2008 | 01:29 PM
Mashimaro's Avatar
OEM Honda filter, OEM Acura RDX Synthetic Oil (5w30)
Old Nov 21, 2008 | 02:36 PM
CDUB's Avatar
That's what I use as well.
Old Nov 21, 2008 | 03:00 PM
batallic's Avatar
amsoil 5w 30
Old Nov 21, 2008 | 03:07 PM
neof69's Avatar
castrol syntec full synthetic 5w-30 with OEM honda oil filter.
Old Nov 21, 2008 | 03:54 PM
Lo-Buck EF's Avatar
where do you get the euro formula? i've been looking around for it but havent come across it.
Old Nov 21, 2008 | 05:10 PM
bobmugen's Avatar
Mobil1 Oil filter with Mobil1 full synthetic 5w-30
Old Nov 21, 2008 | 08:10 PM
BoS_DC2's Avatar
HAMP filter and 5w30 synthetic blend. Not brand religious.
Old Nov 21, 2008 | 08:54 PM
slofu's Avatar
HAMP or OEM S2K filter (other Honda filters are Honeywell/Fram ****), Shell Rotella T Synthetic 5w40 + STP or other Zinc additive (wasn't necessary before Shell removed most of the Zinc from even their best Diesel oil). With a good air filter this combo works well for longer oil change intervals for me, including track usage.
Old Nov 22, 2008 | 12:48 AM
clem kevin's Avatar
you can typically find it at autozone, it will say on the back that it was made in europe or whatever
Old Nov 22, 2008 | 04:06 AM
irev210's Avatar
yah i've had good luck at autozone "made in germany"
Old Nov 22, 2008 | 11:03 AM
Jay D. Em's Avatar
yup, autozone... and they usually have specials on castrol too so it works out nice.
Old Nov 23, 2008 | 07:58 PM
Devon M's Avatar
Well I think that I am going to go with 5w 30 royal purple, and an oem s2k filter.
Old Nov 23, 2008 | 08:39 PM
dc2 specR's Avatar
Motul HTech 100
Old Nov 23, 2008 | 10:13 PM
blacK_Dc4's Avatar
I thought RP and Amsoil are both great high performance oil ( that cost more than $6 a quart retail ) .. any reason you use Amsoil instead of RP when you track it and use RP for street ?
Old Nov 23, 2008 | 10:24 PM
99SlammedCivic's Avatar
Snipper Snapper
7'11 special oil & same filter ftw jk
Old Nov 23, 2008 | 11:34 PM
clem kevin's Avatar
fell out of vtec at about 6500 rpms using royal purple at buttonwillow. The oil got too hot/thin and the engine just couldnt take it. Figured if im gonna use some thick oil, use oil that is clearly thicker and a bit better performance, and go with amsoil. Its more expensive than the RP so i use that for normal street use, since i think its fine. I met one of the top dogs for RP one time and after my discussion with him, i figured i liked the product, just not on the track.
FlewByU352
Oct 9, 2009 07:26 PM
dsmslyr55
11
May 11, 2009 11:22 AM
tekniq
34
Jun 11, 2008 09:40 PM
civic_saints1
Feb 17, 2008 04:27 PM
accord94
Mar 16, 2003 10:25 PM
