car vibrating when gas is pressed
Old Nov 21, 2008 | 09:25 AM
vlc92189's Avatar
Default car vibrating when gas is pressed
hey guys kinda got a problem, last night when i wass driving, my car would shake when i was accelerating. i think it's either my wheel bearing or my axle as i will check this weekend. if it was to be my axle or wheel bearing what would i buy them for? i have a 98 civic with a 94 jdm b16. thanks guys
Old Nov 21, 2008 | 10:00 AM
00b20vtecoupe's Avatar
axle... get a 2000 si axle like 60 bux lifetime at advanced or autozone or wat eva.
Old Nov 21, 2008 | 10:12 AM
mortificationrock's Avatar
Could also be some bad motor or trann mounts too....
Check that and then also look into the axles. and like he ^^ stated get some B series axles.
Old Nov 21, 2008 | 10:14 AM
marcs1337's Avatar
its possbile it could be an axle, but why would it only shake on acceleration? the axle is always spinning as long as the vehicle is moving,same with the wheel bearing...i personally think its more of an engine/trans mount...
Old Nov 21, 2008 | 10:15 AM
Mr.Chow's Avatar
sounds like an axle to me....make sure you get one with a lifetime warrentee...lowered cars eat axles much quicker than stock.
Old Nov 21, 2008 | 10:36 AM
zerovandez's Avatar
when I swapped my ek with a JDM GSR, I had similar issues. I replaced the axles with Cardone Si units and it's been fine ever since.
Old Nov 21, 2008 | 06:26 PM
vlc92189's Avatar
thanks.. i actually have been noticing lately that my engine mounts are about shot so ill look at them this weekend, thanks guys, so a 2000 si axle will work?
Old Nov 21, 2008 | 07:41 PM
ejLday's Avatar
axle axle axle. find out which one is bad and replace.
Old Nov 22, 2008 | 08:12 AM
vlc92189's Avatar
so i havent drove the car in two days, then i drove it this morning, checked the mounts and no vibrating. i did not go over 50 when usually over 50+ is when i feel the vibrating, but im going to take a look at it thorougly tommorow when iget home. ill let you guys know, thankss.
Old Nov 24, 2008 | 02:02 PM
marcs1337's Avatar
any news? im pretty set on it being the mounts...my sol does the same thing between 60-70 mph
CoolRedXylophone
10
Dec 15, 2009 03:17 PM
wu tang
Dec 14, 2007 05:31 AM
FormulaGSR
Oct 5, 2004 04:34 PM
AaronJ
11
Dec 3, 2003 09:37 AM
d_mina
Nov 27, 2003 12:09 PM
