B-series installed what factory rear mount is used
My buddy has a gsr dropped in the hatch, and now it's time to change out the rear mount. What rear mount should he be using? The factory d-series mount in the back or order a Integra rear mount?
Not quite, rear T bracket yes. But the actual rubber mount is the original civic unit in both cases. Although in the case of the '96 - '00 I see no reason why you couldn't use an Si mount, should fit just like a D-series, not so sure about using an integra mount in a '92 - '95
B series rear mount will work in 92-95 except that of 99-00 the mount on the motor and tranny is same but not on the fire wall ie: im usin a 2000 SI tranny JDM B16 i used B series integra rear mount in my eg
fourthgenhatchB17
May 22, 2006 10:13 PM
Greg456
Apr 8, 2004 09:49 PM
for you sir!
