type r cams in b16a2?
Old Nov 21, 2008 | 07:10 AM
beesting00si's Avatar
Default type r cams in b16a2?
would type r cams be a plus?
Old Nov 21, 2008 | 07:19 AM
duefuss's Avatar
yes they would not much but they have a longer lift and duration than the B16 cams and the vtec lobes are more aggressive, if your going to spend 350 on ITR cams why not go skunk2 stage 2 cams?? the ITR cams are equivelant to a mild stage 1
Old Nov 21, 2008 | 07:22 AM
red_crx's Avatar
Originally Posted by duefuss
yes they would not much but they have a longer lift and duration that B16 and the vtec lobes are more aggressive, if your going to spend 350 on ITR cams why not go skunk2 stage 2 cams?? the ITR cams are equivelant to a mild stage 1
With stage 2's he will more than likely need to upgrade springs/retainers..plus he would need more compression to benefit from the stage 2's
Old Nov 21, 2008 | 07:31 AM
Rok_Stok's Avatar
The CTR and ITR have upgraded valve springs over the stock B16A2 to begin with. Using CTR cams will net you gain, but personally, if I had a B16 I would get a much heftier set of cams and valvetrain. Make your B16A2 eat a B16B. For quick compression get a Mugen head gasket (or spoon but I'd get the mugen) and have the head milled a few thousanths, if you don't want to swap pistons. Remember that if you mill the head you'll want to retard cam timing a couple of degrees, then advance ignition timing by a few degrees. Haha, I'm getting a little ahead of the topic here.
But if you're truly set on using Type-R cams in your stock B16A2, yes you will get gains, just remember the stock valvetrain's limits.
Old Nov 21, 2008 | 07:58 AM
duefuss's Avatar
<<<<<<<<running skunk2 stage 2 cams in JDM B16 stock valve train no prob valves are not floating at high rpm....
Old Nov 21, 2008 | 08:15 AM
reaction360's Avatar
with the lack of torque in a b16, you would gain from upgrading the valve train and revving the **** out of it with a good set of cams.
you also gotta consider what you do with the car. are you keeping it na? going turbo? etc....
Old Nov 21, 2008 | 10:09 AM
luvmihatch's Avatar
i upgraded my gsr valve train to type r... and i have the 2001 jdm type r cams. and wow they are a big differance. i love it.. my car put down 194 on a stock bottom end withteh type r valve train skunk 2 intake mani hytech headerinjectors and good tune..
i def recomend it..
Old Nov 21, 2008 | 10:44 AM
underb00steg6's Avatar
i def recomend it..
looks like a nice set up you have
Old Nov 22, 2008 | 10:08 AM
i do plan on turbo later on down the road, i jus want some mild horsepower gain for now
Old Nov 22, 2008 | 10:09 AM
so ITR cams are not a bad idea haha
from what everyones saying i should notice somewhat of a difference?
now if those cams are in, where the vtec kicks in, would that be affected?
im sorry ive only had my honda for like 5 months haha and i dont know much about it
Old Nov 22, 2008 | 10:43 AM
B.'s Avatar
B.
400 HP Club
I only run the exhaust cam from the ITR. The lobes aren't much different on the intake side from the b16a2's
Old Nov 22, 2008 | 01:56 PM
Juan_Mitosis's Avatar
Isn't it all the way around dude? The exhaust side is identical, and the intake side is what is more aggresive on Type R?
Old Nov 22, 2008 | 03:11 PM
mikeycivic's Avatar
the intake is more aggressive not the exhaust cam
Old Nov 22, 2008 | 06:26 PM
z6hatchboy's Avatar
x2
Old Nov 22, 2008 | 06:38 PM
EFRue57's Avatar
x3
this is what we put in both my brother's ls/vtec and a gsr motor and did have noticable gains. good way to do a reliable upgrade.
Old Nov 22, 2008 | 06:44 PM
Rok_Stok's Avatar
x4
Oh wait a minute, what's up with this?
Measured with 0mm of lift
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-278 dur. / 11.5mm lift
Exh-280 dur. / 10.5mm lift
Old Nov 22, 2008 | 07:10 PM
robfrmny21's Avatar
when your valve floats you will know cuz its gonna drop a valve. your gonna run out of luck soon seen it be4 ... you will drop it on the exhaust side
Old Nov 22, 2008 | 10:22 PM
Christopherian1982's Avatar
So what you guys are saying is, its better to just swap out the intake cam since all the power is on that cam?
Old Nov 23, 2008 | 03:42 AM
B.'s Avatar
B.
400 HP Club
yes you're completely correct. My mistake, I was all 420'd up when i made that post LOL. sorry for the confusion.
Old Nov 23, 2008 | 04:39 AM
mikeycivic's Avatar
If you want to do it right, find yourself a ITR/CTR valvetrain and either the 99-00 itr cams or a set of ctr cams. If you find just an intake cam that should be good too since the exhaust cams are so close that the gains arent really noticeable.
Old Nov 23, 2008 | 05:07 PM
Are there any down side to just putting a intake cam without changing out the valvetrain. I wonder cause im always a thumbs up for power. And I have a B16 with a greddy turbo setup. Lemme know what you guys think?
Old Nov 23, 2008 | 05:44 PM
Old Nov 24, 2008 | 06:46 AM
Rok_Stok's Avatar
You can, and you will have a slightly higher powerband, but don't rev past the stock valvetrain's limits, or what the stock rev limiter was.
Old Nov 24, 2008 | 09:25 AM
how do you know when you reach the stock valvetrain limit?
Old Nov 24, 2008 | 09:28 AM
are you talking about red line limit.
