Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Sway Bar ????
Old Nov 21, 2008 | 07:01 AM
civicguru's Avatar
Default Sway Bar ????
Hi Guys,
Mine is a 08 LX sedan and am thinking about installing/upgrading front and rear sway bar's.....is an OE SI setup good or should I go with some thing else.....I mean I see a Si set up on ebay going for $158...but if I going to spend that kind of money I might as well spend some more and get the best value for my $$$...any suggesstion???? any links???and direction of where to buy it from and what....
The OE SI front measures 28.5 mm and the rear 17.5mm. here is the link for the listing
http://cgi.ebay.com/ebaymotors/ws/eB...8623&viewitem=
...is this a good deal...or can I get some thing better than this I know the rear @17.5mm are thin....?????
any help would be nice....
JFK
Old Nov 21, 2008 | 08:03 AM
civicguru's Avatar
The ebiach ones are 19mm rear and 32mm front for $259....is this good resonably priced...or will this make it way too stiff???
Old Nov 21, 2008 | 11:16 AM
a1staecksauce's Avatar
From: Westminster/Huntington Beach/Seal Beach, CA, United States
keep your lx front sway and upgrade to the progress rear sway which is 22mm. It'll make the car rotate better.
Old Nov 21, 2008 | 12:00 PM
civicguru's Avatar
hey a1.......what do you mean by "rotate" r u serious...I mena I am confused....will it handel better in shrap turns or will be make dougnuts better......I want better shrap handelling and not the ability to ROTATE well that is the last thing i want.....
Old Nov 21, 2008 | 05:16 PM
rotate as in the back end will be more willing to come around. Don't worry its not like you'll be drifting every freeway on/off ramp and you won't be spinning out of control on every turn. A thicker rear sway will just stiffen up the back and make the car turn better/sharper. less understeer
Old Nov 22, 2008 | 04:51 AM
Overdosedvtec's Avatar
EIBIACH MAKES A FRONT FOR US?
Old Nov 22, 2008 | 07:54 AM
RICO_'s Avatar
NO MERCY!
Originally Posted by civicguru
Hi Guys,
JFK
The Si upgrade would be pretty significant compared to the sizes of a stock LX sway bar setup. Stiffness of sway bars increases dramatically proportional to the diameter of the bar. So you will notice a big difference just by upgrading to the Si rear sway bar and keeping the LX front sway bar considering you're going from a stock 11mm to 17mm....which is a huge jump.
Old Nov 22, 2008 | 05:15 PM
civicguru's Avatar
thankx guys....good info...may be I will just do the si rear....but what if I do the eibach...will it make it too stiff or it should be fine...I am riding on 17" adr rims with wide tires I also have the front strut brace in... will be installing it pretty soon........so what do you guys think should i go with the eibach 19mmrera &&& 32mm front????.....oh btw what is the stock in mm for the lx???...just curious to know what kind of jump Iwill be making if I go with the eibach......
Old Nov 22, 2008 | 05:17 PM
civicguru's Avatar
I mean the stock in mm for the front LX ???
Old Nov 22, 2008 | 05:20 PM
K5^'s Avatar
K5^
Brand New
24.2mm/10mm [f/r]
Old Nov 22, 2008 | 05:29 PM
civicguru's Avatar
one last question ..is it required that the front and rear have the difference in mm...I mean some one above suggested that I could just put in a rear progressive 22mm sway and call it a day woudn't this bring the front and the rear very close in dimensional mm's.......
thankx for all your inputs guys...
Old Nov 22, 2008 | 05:46 PM
K5^'s Avatar
K5^
Brand New
Not necessarily. The fronts are just generally greater in diameter because of the added lateral loading in the front compared to the rear. The point of adding a stiffer rear end is to give you better yaw, or rotational response [think of an xyz coordinate system, yaw would be rotation about the y axis].
stuie08
Nov 25, 2006 02:30 PM
Nisif
16
Jan 24, 2006 07:53 PM
Cuong-nutz
Suspension & Brakes
Aug 8, 2005 03:45 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
spun Vtec
Nov 13, 2002 05:51 PM
