1996 ek with 1995 h22
Old Nov 21, 2008 | 02:19 AM
kyleclapp's Avatar
Default 1996 ek with 1995 h22
I live in California and as most of you know we have the strictest emissions standards in the US. I made the mistake of buying a 1996 Civic Dx with a 1995 Jdm h22. See what i mean? Basically what i am wondering is, is it possible to convert an obd1 motor to obd2? As far as I've read the only difference is a second o2 sensor, distributor, injectors and a couple other sensors. I would like to know if anyone has done this, and if it is possible how hard would it be and what exactly would i need to do it?
Thanks
Old Nov 21, 2008 | 05:48 AM
LA_HONDAS's Avatar
Originally Posted by kyleclapp
I live in California and as most of you know we have the strictest emissions standards in CALIFORNIA. I made the mistake of buying a 1996 Civic Dx with a 1995 Jdm h22. See what i mean? Basically what i am wondering is, is it possible to convert an obd1 motor to obd2? As far as I've read the only difference is a second o2 sensor, distributor, injectors and a couple other sensors. I would like to know if anyone has done this, and if it is possible how hard would it be and what exactly would i need to do it?
Thanks
FIXED THAT FOR YOU
put a obd2 ecu in it and the other o2 sensor and you should be good to go
Old Nov 21, 2008 | 12:57 PM
kyleclapp's Avatar
Originally Posted by LA_HONDAS
FIXED THAT FOR YOU
Thank you, so your saying that with an obd2 ecu and adding a second o2 sensor i should be able to smog it?
Old Nov 21, 2008 | 02:13 PM
teefunk01's Avatar
our laws in Mass is pretty tough but nothing compared to cali
Old Nov 21, 2008 | 04:09 PM
iwanttokillgod's Avatar
obd2 motors have a crank angle sensor there is a way to bypass it if your gonna run a obd2 ecu on a obd1 motor and not change the crank
Old Nov 21, 2008 | 04:20 PM
LA_HONDAS's Avatar
why you have to change the crank?
you just have to change the timing belt pulley on the crank
R.GroomsH22
Jan 21, 2013 09:06 PM
JDMDC4life
Jan 16, 2008 08:36 PM
BLUE EH3
Sep 10, 2005 04:04 PM
h22dx
Apr 13, 2003 01:38 PM
