transmission fluid
Hello I just wanted to ask about the transmission fluid capacity. I have read that it was 2.3qt, but I had only put 2qt of Honda manual transmission fluid and wanted to know if there was anything wrong without putting the entire amount? Also the transmission is a s4c from a CTR.
Fluid capacity for a b-series manual tranny is indeed 2.3 quarts.. After you put your 2 quarts in.. just keep adding a little untill the fluid barely starts to spill out.. and you should be good.
Also If you only have 2 quarts of the genuine honda manual tranny fluid then for the .3 just use regular 10w-30 motor oil.. it will be fine.
mysicivic1991
Apr 16, 2007 09:53 AM
