2005 Accord Glovebox Rattle
The glovebox door on my 2005 Accord EX is rattling and beginning to drive me crazy. If I put pressure on the door with the heel of my hand it subsides. What can I do other than spending a fortune to have the dealer fix it?
This is a Technical Service Bulletin (TSB) for 98-99 Accords; but, try seeing if your 2005 Accord has the similar rubber stops. If so, they may be worn out.
http://www.tegger.com/hondafaq/tsb/accord/x99-090e.pdf
Also, check this post out regarding how someone fix their rattle in a similar year Accord as yours:
http://www.driveaccord.net/forums/sh...ad.php?t=22961
Google the subject, and you will find answers regarding how to fix the glove box rattle.
Like said above on the right side of the glovebox there is an arm attached to a shock reattach that and your rattle should go away
in addition to what is said above if you pull the glove box down, look at the striker and follow the bracket it attaches to, to the 8mm bolt. if you loosen it and push the stricker back a little bit and retighen that should take care of the noise.
The glove box light is on, when ever the lights are on. It goes out when you turn the lights off. That's just the way it works. No problem.
TOMSBLUEHONDA23
Sep 29, 2005 07:11 AM
