B Series brackets into an SOHC EK
Old Nov 20, 2008 | 01:10 PM
david76008's Avatar
Default B Series brackets into an SOHC EK
I need all the B series mounts, but can't seem to find a chart on what I need.
I'm hoping someone has a pic of all the brackets so I can tell apart from each other. Or just the location of them.
Thanks so much :-)
Old Nov 20, 2008 | 03:39 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Here ya go. These are all the mounts for a B16 Si:
If you're swapping a running SOHC out of the car, you won't need all of that, because several of your D series components will work. Off the top of my head, I believe all you need is 1, 4, 6, and 7 in that diagram, plus the associated bolts, assuming you're swapping out a D series.
And really, you only need the top part of 4 because the bottom is the same as the D. And I believe all the round rubber parts are the same.
Old Nov 20, 2008 | 08:36 PM
david76008's Avatar
Ok,
I got a couple of questions.
These are the brackets I got so far. Which ones do I still need?
**NOTE**My car came with NO brackets. ZERO/ZIP
And second, I got 2 T/L brackets for the tranny, but they are both different.
Can anyone tell which one looks to be the one for an EK?
Old Nov 20, 2008 | 09:45 PM
scbmx87's Avatar
I just ran out to my car at 1:43 AM to check for you, LOL. Its the bracket on the right. I just put a B series in my 97 Coupe.
It looks like you have all the mounts you need, but you may want to pick up a torque mount since you're using the OEM motor mounts. Its numbers 8 and 10 in that picture.
I used a set of Hasports in my car, so I didn't run a torque mount. Its not a necessity, but it won't hurt.
I actually have a torque mount i'll sell you for $35 shipped, i dont need it. They're about $70 from hondaautomotiveparts.com.
PM me if you want it.
Old Nov 21, 2008 | 08:54 AM
david76008's Avatar
Pmed.
So is #8 and 9 the same in the pic? Meaning I need 2 of those?
And am I missing #3 or is that a mount?
Old Nov 22, 2008 | 02:04 PM
david76008's Avatar
~TTT~
Frost7177
Mar 24, 2009 07:47 PM
delboost
May 20, 2008 08:42 AM
Fallen86
Feb 14, 2006 04:58 PM
