B Series brackets into an SOHC EK
I need all the B series mounts, but can't seem to find a chart on what I need.
I'm hoping someone has a pic of all the brackets so I can tell apart from each other. Or just the location of them.
Thanks so much :-)
Thanks so much :-)
318 Curves, 11 miles
Here ya go. These are all the mounts for a B16 Si:
If you're swapping a running SOHC out of the car, you won't need all of that, because several of your D series components will work. Off the top of my head, I believe all you need is 1, 4, 6, and 7 in that diagram, plus the associated bolts, assuming you're swapping out a D series.
And really, you only need the top part of 4 because the bottom is the same as the D. And I believe all the round rubber parts are the same.
Ok,
I got a couple of questions.
These are the brackets I got so far. Which ones do I still need?
**NOTE**My car came with NO brackets. ZERO/ZIP
And second, I got 2 T/L brackets for the tranny, but they are both different.
Can anyone tell which one looks to be the one for an EK?
I just ran out to my car at 1:43 AM to check for you, LOL. Its the bracket on the right. I just put a B series in my 97 Coupe.
It looks like you have all the mounts you need, but you may want to pick up a torque mount since you're using the OEM motor mounts. Its numbers 8 and 10 in that picture.
I used a set of Hasports in my car, so I didn't run a torque mount. Its not a necessity, but it won't hurt.
I actually have a torque mount i'll sell you for $35 shipped, i dont need it. They're about $70 from hondaautomotiveparts.com.
PM me if you want it.
Pmed.
So is #8 and 9 the same in the pic? Meaning I need 2 of those?
And am I missing #3 or is that a mount?
