Instaling a Subs/Amps Noob Question
Old Nov 20, 2008 | 09:21 AM
x4and3r1991's Avatar
Default Instaling a Subs/Amps Noob Question
I have a 99 civic and i want to instal subs and an amp into it, i got all the wires, subs, and amp. but my deck doesnt have the RCA outputs into it. is there any way i can instal the amp without using RCA Cords? any help will go, i heard to use a high powered amp. but how do u know if its high powerd? my subs all both 600w each, and so is the amp. thank you in advance.
Old Nov 20, 2008 | 11:57 AM
B18C_EJ8's Avatar
You need a line out converter. They're also known as line-level converter or "hi-low" converters.
Instructions will be on/in the package.
Old Nov 20, 2008 | 02:49 PM
lee0149's Avatar
i think you can go to best buy and buy something to do it. i advice is to get a new deck. more power and more eq
Old Nov 21, 2008 | 09:15 AM
wat is an in line converter and were does it go?
Old Nov 21, 2008 | 10:19 AM
B18C_EJ8's Avatar
I don't recall saying anything about an in line converter.
*rereads posts* Nope. Sure didn't.
I do, however, see that I mentioned that instructions will be on or in the package. Or, you might try a Google search for the proper name of the device in question.
Old Nov 21, 2008 | 03:33 PM
It Wasn't Me's Avatar
Make and model of amp and subs?
Many amps have "speaker level/high level" inputs, which you connect your speaker wires to, instead of using RCA's. Check to see if your amp has this feature.
Old Dec 9, 2008 | 09:38 AM
hmm forgot wat model but its a sony xplod amp and deck, my amp does accept speaker wire.
Speakers wires connecect to the amp and speakers. the amp connected the the battery and ground. amp also conected to remote wire. thats wat i got so far, cant use RCA cause theres no outlet in back of deck, thanks for any adive
Old Dec 9, 2008 | 11:12 AM
mrdeadman's Avatar
They let me pick
Get a line out converter. These can be had for about $20 at best buy or ciruit city or car toys or anywhere like that. This gets spliced in behind your hu and then you can run rcas to the amp. Do not use the high-level input. Listen to b18c ej8.
Old Dec 9, 2008 | 11:15 AM
fcm's Avatar
fcm
Old Fart
"its a sony xplod amp and deck"
???You have a Sony HU, [deck] that does not have RCA outputs???
We need model numbers to be able to help you, go look on the amp and deck for the model numbers. 94
Old Dec 9, 2008 | 11:16 AM
B18C_EJ8's Avatar
Originally Posted by mrdeadman
Listen to b18c ej8.
LOL, thanks...
I had a reply typed out but I figured that since I'd already answered this guy's question twice, I wasn't going to bother trying to help him again... It started out with "Are you fuc king serious???"
Old Dec 9, 2008 | 11:17 AM
mrdeadman's Avatar
They let me pick
Originally Posted by B18C_EJ8
LOL, thanks...
What a coincidence. My reply did too, but I deleted it just before I posted...
Old Dec 9, 2008 | 11:49 AM
They're there for a reason. The converters are handy, though.
Old Dec 9, 2008 | 01:43 PM
mrdeadman's Avatar
They let me pick
High-level input sucks.
Old Dec 9, 2008 | 02:42 PM
imsickofrice's Avatar
get a hi-lo convertor.. you hook up +/- for 2 speakers, and there you go.. you have rca outlets..
Old Dec 9, 2008 | 02:54 PM
This may be, but we're clearly not dealing with an audiophile.
I'm curious what his budget is. It may be worth it to just buy a new (or used) HU that has RCA outputs (preferably with a sub output) and call it a day. Like fcm, I'm curious as to why his Sony HU does not have any RCA outputs. It must be rather old.
Old Dec 10, 2008 | 04:02 AM
mattison187's Avatar
line-level converter FTW...
94 IntegraLS
Audio / Security / Video
Dec 29, 2007 06:15 AM
BB6-213
Nov 12, 2007 04:51 PM
lickety_britches
Aug 9, 2007 01:31 PM
ludeguy98
May 5, 2004 01:12 PM
JamesQ
Dec 21, 2003 11:48 AM
