Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow Perches
Old Nov 20, 2008 | 08:30 AM
bopbop93030's Avatar
Default Koni Yellow Perches
Hi,
Got mine yesterday and I have only 2 perch instead of 3 is this right?
I have an Accord so it might be different than the Civics and Integra's
If I lower the perch will that mean that I will have less shock travel?
Thanks
Old Nov 20, 2008 | 03:31 PM
Targa250R's Avatar
be professional
Originally Posted by bopbop93030
Hi,
Thanks
Correct on both counts.
If you are using lowering springs or coilovers, set the circlip in the upper groove. If you are using stock springs, you can use either the upper or lower groove depending on your ride height preferences or needs. Remember to have the wheels re-aligned if you install the circlip in the lower groove.
Old Nov 21, 2008 | 11:05 AM
hard to imagine that the circlip is the only thing holding the shock.
Manolo
Suspension & Brakes
13
Apr 18, 2006 08:24 PM
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
cmdr430
Honda S2000
10
Apr 17, 2005 11:05 PM
cd5_2NR
Jul 9, 2004 01:07 AM
Philbert
Feb 10, 2002 05:34 AM
