89 CRX Si has intermittent blower operation
Old Nov 20, 2008 | 07:35 AM
roadhead's Avatar
Default 89 CRX Si has intermittent blower operation
That lately has been getting more intermittent. It used to be a sharp blow to the area below the glove box would bring it back on for a few days/weeks/months - but as of late that trick isn't working as often as it used to.
Is this the infamous "blower motor resistor" I've read about? Or could it be something with the HVAC control slider itself?
Luckily I have a parts car that was blowing strong when I ripped the engine out of it, so there is a bright side there.
How likely is it to be a loose/corroded connection?
Old Nov 20, 2008 | 07:50 AM
Jonathan_ED3's Avatar
Typically if the resistor is out it will work on the highest speed but not on one or all of the lower blower setting speeds.
Old Nov 20, 2008 | 07:58 AM
roadhead's Avatar
So the more 'binary' nature of the problem indicates another cause? Because its either blowing, or it isn't, regardless of fan-speed setting.
Old Nov 24, 2008 | 01:42 PM
So you are saying that when it works, it works on all fan speeds?
And when it doesn't work, it doesn't work on any setting?
My car has done that before. It was a very intermittent problem. I took the plug off (at the resistor) and cleaned it all up and put in dielectric grease and it hasn't done it since.
Old Nov 24, 2008 | 01:50 PM
roadhead's Avatar
Yes sir, you hit the nail right on the head. So I need to remove the blower and get at the plug behind it then? I started this on my parts car and I could tell its not going to be a fun afternoon.
Also, today on the way to Wal-mart it randomly came on again, and has now been working all day.
So random. OK, I'll check the plug and apply more grease, thanks for the tip.
Old Nov 24, 2008 | 02:26 PM
1990hondacrx's Avatar
not to try and steal your thread but i kinda have the same problem mine will blow only on setting 3 and 4 but wont blow on 1 or 2 setting why is this? i took this blower motor out of my parts cars which it worked fine in or is it the fan relay? id like to kno myself
Old Nov 24, 2008 | 03:25 PM
Your question was answered in my original post in this thread....
It sounds to me like your blower resistor has failed!
Old Nov 24, 2008 | 07:09 PM
Crx Jimmy's Avatar
the blower motor is on the way out. you can try beating on it with a hammer it might give you a couple more months, water usually gets in and rusts them up
scottmog
Mar 1, 2008 02:21 PM
Topshot
Jan 4, 2008 10:09 AM
aquabob89
Apr 26, 2006 04:23 PM
sonikempire
Jan 14, 2006 08:52 PM
SwissChEz82
15
Nov 15, 2004 02:40 PM
