Rolling odometer
Now my crx has a 189k, im installing an edm cluster (139k) so i want to roll it forward to reflect the correct mileage. Now i cannot simple swap odometers cause the edm has no 1/10th and the usdm one does. Anyone have any info on how to do this?
I have posted 2 times with instructions and then this new format says i'm not logged in. Let me try one more time. I have done this mileage reset on my UKDM speedometer/odometer. It is in the FAQ, third post, under interior, but it looks like the pictures are gone(I don't know how to link to it). I was able to reset without removing the odometer from the speedometer, but it helps if you have a set of very thin nose needlenose pliers. On the side of the number discs(where the 1/10th would be) there is a small "c" clip that you remove, then slide the discs over until they freely turn. Reset the mileage, slide the discs back over one at a time,(you will feel the shaft ingage the discs) reinstall the clip and reinstall the speedometer into the cluster. I would suggest that you do all of this over something that contrasts with the color of the clip because you will drop it a few times before you get it back in place.
If you only need to adjust the last couple digits you can use a dental pick and pull the last digit over and then spin it same with the next one. You shouldn't have to remove anything. They only go in one direction I don't remember which way so be careful.
JDMJUNKIEMONKIE
11
Feb 2, 2010 09:41 PM
B96v6
Dec 23, 2009 05:49 PM
wickedEFguy
Dec 29, 2005 09:51 PM
Sliced Beard
Aug 28, 2004 03:03 PM
