Upgrading fuel setup opinion and questions
Old Nov 20, 2008 | 12:44 AM
Green Lude 93's Avatar
Default Upgrading fuel setup opinion and questions
Im currently running H22, 1000cc, turbo, with walbro. My tuner said that it starts leans out at 14 psi at 100% duty cycle so were running the duty cycle a little less at 12 psi 412hp. He believes there is something up with the fuel setup . I tried a new ground and relaying it to better source for power. I think the pump took a crap so I am upgrading to a sx performance inline. Im mounting the pump on my fire wall and im thinking bout running -10 to the pump and -8 to the fuel rail from the pump. I havent heard of many people running -10 to the front due to loss of pressure but the pumps are usually mounted in the rear. Do you guys think I maintain fuel pressure more consistant if i do it my way or should i just run the -8 to the pump and -8 to the rail from the pump? I plan on just running my stock fuel return since its almost a -6 anyways. Also how would i set up the fittings at the tank? The factory is the hose with a clamp style. Do i just leave the intank pump in?
viet_boi_racin
Feb 3, 2008 09:34 AM
dome
Sep 25, 2007 02:50 PM
servion
Sep 17, 2004 12:29 PM
gookspeed
Nov 12, 2003 06:21 AM
W.Zero
Dec 12, 2002 03:08 PM
