ef hatch parts compatability
i picked up a 90 civic si shell yesterday and im trying to piece a motor togeher out of all the junk i have. so i put a d16a6 tranny, dizzy and intake mani on a d15b7. my questions are will 89 crx si shift linkage fit? and has any put ek seats in a civic or crx? im sure they could be made to fit but i dont want to do the work to sit extremely high up in the air. one last question are all d16 injectors the same? i have the injectors off my stock d16y7 (obd2a)
out of my 96 civic and want to know if they work with the setup im putting together.
ive searched but found nothing. tia
No your injectors will not work without modifications. The injectors will work if you bypass your resistor box.
Old injectors like those on the 88-91 Civic are low impedance. You need the resistor pack to use them. If you measure one with a mutimeter set to ohms the horseshoe looking symbol they will read low single digit numbers like 1.1ohms.
Newer injector do not use a resistor pack and will read higher impedance or ohms, somewhere around double digits like 10ohms or higher.
here is an awesome guide to stock injectors
http://www.robietherobot.com/Storm/f...ectorguide.htm
Your shift linkage should be the same. The 88-91 chassis is almost identical.
Sorry don't know about the seats.
GoFastMotorSports
Jan 17, 2005 02:43 PM
