93 accord fuse
alright im sure most of you had something similar at some point. hooking up new deck and blow a fuse. no tail lights (but i do have brake lights... wtf?) and the guages/speedometer arent lit up. parking lights out aswell. got ticket for it. what do you think? what fuse is it??? and yes my wires are loose at the moment and i know which wire shorted but i dont know what it shorted too.
need help asap.
need help asap.
If it had been just the dash lights, I would have said you most probable pinched it between the radio chassis and a dash support. They could have pinched wire/wire and gotten the same effect.
But this also involves the tail Lamps too.
Look specifically for the Tail Lamp Fuse. It powers all the non-Stop Light bulbs in the rear and the dash illumination system takes it's power from the Tail Lamp Circuit (post fuse).
As a long shot, check that you don't have any water sloshing around in one of the tail lamps. It's not uncommon for this generation Accord's lamp / body gaskets to dry out - allowing water into the lamp. You MAY have a damaged lamp socket - thus the blown fuse.
P
P
Honestly before even posting this you should of popped the fuse box under the hood, looked at the diagram located on the cover of ever fuse box and determine which one had to do with the problems, pulled them and checked them..
Then you should of looked at the fuse box under your dash on the driver side..
thank everyone. it was under hood. i do collect water in right tail light but thankfully nothing has resulted from it. im not too good with electrical so before i go playing things to figure it out i prefer to ask. problem solved ticket clear.
that's good you got it resolved but you should take action in getting the water out of the taillight asap as this can cause damage.,...easiest way is to use a small rotary sander and make a drain hole at the bottom of the tail light
Better still:
Have Honda order up the correct Lamp / Body gasket and install the ^%$&# thing!
You're gonna end up doing it anyway drilling holes or not.
Hint... the gasket will fix it.
P
P
andyw1214
Nov 14, 2016 10:41 PM
jjenks
Feb 23, 2010 08:03 AM
blackakkord
Jan 31, 2008 05:46 PM
4DooRGiSzer
Mar 31, 2005 06:44 PM
