Temp Problem
Old Nov 19, 2008 | 04:53 PM
instructor74's Avatar
Default Temp Problem
Okay I know the cause of my problem what I want to know is has anyone had this problem if so what did you do to solve it. Stock 93 civic si replaced the radiator 6 months ago with a dual thickness aluminium unit. The car runs great no overheating issues. Now that winter is here I have the problem of it running to cool. This makes it hard to get the car warm inside. I thought about running a higher temp tstat but that is only going to help with warm up not so much keeping the temp up. The other thought I had was blocking off a portion of the rad to effect its cooling ability
Old Nov 20, 2008 | 04:22 AM
Bump lets see anyone can answer this?
Old Nov 20, 2008 | 01:09 PM
EvilleEG's Avatar
Is your thermostat good? My roomates car did this and would stay cold a lot. we replaced it and its all good now.
Old Nov 20, 2008 | 01:28 PM
Perfectionist's Avatar
The T-stats job is to keep the water jacket around the engine at a specified temperature. If your radiator has the capacity to overcool, the T-stat should be able to restrict the flow and maintain the desired temperature. Are you sure the current T-stat is functioning properly?
Old Nov 20, 2008 | 04:22 PM
wrenchez81's Avatar
put a piece of cardboard in front of your radiator!
Old Nov 20, 2008 | 06:29 PM
I have no reason to think it is not functioning properly.Its the same one that was in it last winter before the change of the radiator. The car comes up to temp at the same rate that it always has. I hate the idea of changing the tstat everytime the seasons change
98B18C1
Sep 29, 2005 12:04 PM
crxtreme27
11
Sep 1, 2002 05:37 AM
