CEL 9 on OBD0
Old Nov 19, 2008 | 11:48 AM
Rob91DA's Avatar
Default CEL 9 on OBD0
Having some problems, car is a 91 Integra, OBD0 JDM B16 Swap. Code came up randomly after 6-7 months after swap, code has been there for 8 months.
Car warms up, then after a minute at operating temp it throws a code 9, CYP sensor, followed the troubleshooting flow chart in the haynes manual, cyp sensor checks out at 500ohms, wiring is fine to the ECU, and last step says check for ground on pin B10, it shows ground so it says check for short in wiring. Wires are fine, if you unplug the ecu, the ground doesn't show in the wiring anymore.
So I figured bad ECU, But I replaced it and problem is still there.
Any other ideas? I am trying to find another Dizzy in case that might be the problem still, even though it checked out.
Old Nov 20, 2008 | 09:26 AM
Rob91DA's Avatar
No one?
thecorey
Dec 8, 2008 06:53 PM
Rob91DA
Nov 18, 2008 05:10 AM
91civicEX
Jul 8, 2003 08:27 PM
axhandler
Jun 18, 2003 08:33 AM
carblegal
Jul 23, 2002 05:56 PM
