91 accord help
Old Nov 19, 2008 | 09:28 AM
noy612's Avatar
Default 91 accord help
Hi i have a 91 accord ex 5spd mt. i recently got into a car accident =/ suks but lucky only my bumper nd hood is damage, and radiator is crack. every since my car wont start, and i receive no lights as i turn the key. i change the radiator, check fuse. still the same, i was wonder where would i start changeing or looking at for this problem. no power, but battery is not even a yr old. and i get the 4 way lights on. so please help. im new here, and just need some help on my car.
Old Nov 19, 2008 | 09:42 AM
P_Adams's Avatar
Do any of the other electrical systems work on this car?
Headlamps?
Wipers?
You could have a broken wire to the starter, a blown master fuse, a bad Ignition switch etc.
any additional hints or observations would be helpful
P
Old Nov 19, 2008 | 10:26 AM
Duane_in_Japan's Avatar
It sounds like a pinched wire from the accident blew the main fuse under the hood, check all fuses under the hood and under the dash. Using your eyes is not going to cut it, get an ohm meter.
Old Nov 19, 2008 | 10:14 PM
bseriescrxsi's Avatar
i was in a major front end collision in my 92 accord....check the main fuse under the hood listed as "battery" its a 60A fuse....replace that and you should get your electrical systems back....if it blows right away again pullout the multimeter and start checking wires
Old Nov 20, 2008 | 12:34 PM
slammed4thgen's Avatar
also check to see if any ground were torn or damaged
wetzelman1
Apr 7, 2010 04:32 PM
jaysin04
Feb 1, 2010 12:57 AM
naterod92accord
Aug 19, 2007 03:50 PM
georgeda
Dec 27, 2005 03:23 AM
Yourbuggingme
Jul 26, 2004 09:52 AM
