KYB AGX Freezing!
Old Nov 19, 2008 | 05:56 AM
Eclpze97's Avatar
Default KYB AGX Freezing!
Anyone have any idea what would cause my KYB AGX to freeze so they are incredibally stiff? Any suggestions on what to loosen them up
Old Nov 19, 2008 | 06:07 AM
Mr.Chow's Avatar
I'm sure you've probably already tried this, but use that little screwdriver to turn your preload all the way down....I run agx's and use setting "3" on the fronts and setting "1" on the rear, I'm on k-sport springs btw...pretty stiff and not all that low.
Old Nov 19, 2008 | 06:10 AM
95jeremie's Avatar
no clue i have never had this happen to me
i have ran the KYB AGX 4 way adjustiable for about 4 years now
car is dumped and no problems...
have you softened it up via the adjuster on the top?
wtf is going on with the forum????
no spell check??? i'm dislexic... that's not good ha ha
Old Nov 19, 2008 | 07:04 AM
Eclpze97's Avatar
3 in the front and 1 in the rear is what I have mine set on. The front seems to be fine its just the rear is really stiff. It also sits outside not in a garage. No way can they be bad because they are only 2 months old. Thanks for everyones quick replies!
Old Nov 19, 2008 | 07:17 AM
dividedas1's Avatar
its just getting to be that time of year... its getting cold out. i would say unless they are leaking or noticeably broken you should be fine, they will just be a bit stiffer cause its getting *** could out here in the mid-west.
also
apparently spell check should be back some time too... or so they say. i haaaate vBulletin though. definitely is not as nice in my opinion.
Zaraki
Suspension & Brakes
Apr 15, 2012 02:56 PM
greebler
Apr 15, 2003 11:50 AM
akeldama
Dec 30, 2002 09:49 PM
Kolijian
Jun 5, 2002 12:41 PM
