Replacing my valve cover seal?
On my B20 integra.
I searched and could not find much. Dont you have to apply some kind of silicone or hondabond?
What is the proper procedure?
I usually do the following:
1. Remove the valve cover and take off the old gasket (obvious).
2. Make sure you purchased a full valve cover gasket kit including the 4 spark plug hole gaskets.
3. Install the new gaskets supplied in the kit.
4. Only use a dab of silicone at the 8 cam cap corners; 4 points on the timing belt side, and 4 on the distributor side.
5. Carefully reinstall the cover, and be sure not to overtighten the valve cover bolts.
Good luck!
Good luck!
as a check procedure, make sure those "spark plug gasket rings" don't fall off when putting the valve cover back on, cause sometimes they don't stick on very well. I have a friend that had a 2000 model SI and he forgot to put his back on, pulled plug wire and hole was full of oil--- definately not preferred
Thanks, how much is silicone?
Also, what are the 8 cam cap corners?
Sorry, would have quoted, but this new layout is crappy. It wouldnt let me quote, it was perfectly fine before..
And quote works just fine; just click the "quote reply" button on the bottom right.
The cam cap corners can be found on both the left and right side fo the head on the top after you remove your valve cover. they stick up and are aluminum, and they are half moon shaped. Where the contact the head put a small amount of silicone. There will be 8 spots that meet this requirement. Good luck!
I highly do NOT recommend using any type of sealant when installing valve cover gasket. It seats fine if brand new and all you have to do is make sure you cross torque bolts to 7 ft. lbs. If you use too much sealant and when installing cover back on, it will leak into your head and mix with oil=
BAD
BAD
since no one has mention it yet so I say it... clean the mating surface with brake cleaner. it will provide a tighter seal it's free of oil. btw I also don't use sealant. never have and never will. factory manual don't tell you to do so I don't.
Ill be doing my spark plugs as well. Been running the ones my B20 came with over a year ago..
Oh and to an earlier reply, you cant choose to quote from the list of posts below like before as I type this.
Thanks for all the replies, oh and for information purposes I got the felpro valve cover gasket set WITH spark plug gasket rings included for $22 at Oreilly.
Note: Use liquid gasket, Part NO. 08718 - 0001
It does advise you to use it.
themorphious
Jun 3, 2006 12:14 PM
standbackimapro
Apr 29, 2006 05:38 PM
standbackimapro
Jan 20, 2006 09:55 AM
standbackimapro
Dec 16, 2005 11:07 AM
