DC2R/EG6 coilovers on EK4 - Rear LCA
You must use spacers around the lower shock bushing of the '96-00 Civic LCA to run the '92-95 Civic rear dampers. Some stainless washers of the proper size will work.
This wouldnt work if the coilovers are for a DC2R. I always see good deals for coilovers of this application, but have never seen any1 able to fit the Rear assemblies onto the 6th gens.
As kyden mentioned, Function7 makes control arms to use ITR-style dampers on a '96-00 Civic (see here), but they are prohibitively expensive. IMHO, it's only worthwhile if you're finding $300+ savings on high-end dampers that are uncommon to find or are only made in lower eye-mount style (i.e. Bilstein Sport, Koni 3011/2812, Ohlins, Penske, JRZ, Moton, etc.). If you intend to run something common or cheap, it's pointless because it offers no performance benefit for the hassle - just continue looking for a deal on the same dampers with the correct lower mount style for your vehicle.
This is true; I somehow completely missed that he was intending to use dampers with lower eye-mounts. My mistake.
What do you all think of the JDM Bilstein coil overs for the ITR compared to say Ground Control/Koni setups - how about koni monotubes?
Example JDM set - ebay
http://cgi.ebay.com/ebaymotors/JDM-H...ayphotohosting
Thanks in advance for your thoughts.
As for Koni monotubes such as the 3011, you're going to be looking at a much higher initial investment than a Bilstein to gain that adjuster. Whether or not it's right for you depends on what you need to do with them and how much you're willing to spend.
Lil Corb
Aug 22, 2004 06:43 PM
