90 civic sedan alignment?
Old Nov 19, 2008 | 12:02 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default 90 civic sedan alignment?
hey h-t's?i need some help.i just bought a pretty clean 90 civic sedan.the only problem is the alignment is off and the steering wheel is not straight,its off to the right about 2inches.could this be the alignment?is it pretty easy fixed?thanks
Old Nov 19, 2008 | 12:41 AM
exz0n-.-'s Avatar
alignment, tkae it to a shop.. its like 30 bucks
Old Nov 19, 2008 | 12:58 AM
Genetically Gay
yeah,im pretty sure is the alignmt too.i'm gonna jack it up before take it in to shop.just to make sure is not something esle?what do i look for?
Old Nov 19, 2008 | 01:26 AM
exz0n-.-'s Avatar
bent tie rods and such
Old Nov 19, 2008 | 04:15 AM
~sp33~'s Avatar
EFB055
Does it track fine? Any wheel vibrations? Excessive tire noise, scrub marks on your tires?
If not then just unbolt your steering wheel and center it. It's possible the previous owner had a sports wheel or something on there, and swapped the stock one back on when they went to sell it, and just didn't align the steering wheel correctly.
Old Nov 19, 2008 | 01:03 PM
sgallagher's Avatar
NO!! It is true that the steering wheel could be offset by installing the steering wheel in the incorrect location. However, you should test it to check before you just offset the steering wheel to fix alignment issues.
Turn the steering wheel lock to lock and count the no. of times it is rotated devide that no. in half and move the steering wheel to its center position. If your steering wheel is not straight then remove it and install it straight. It is still a good idea to get an alignment afterwards as the guy at an alignment shop can measure where your absolute center is, basically by performing the same procedure just using lasers and a computer. then he will adjust your toe accordingly.
Old Nov 19, 2008 | 11:54 PM
Genetically Gay
heres the update i got it align at the shop.i just took it in..did'nt have time to check it myself to busy..the problem was that they had to replace one side of the tie rod plus aligned.it turn out better than before.later on i recheck everything.i see that both front tires were really in bad shape and couple of the stock steeli had dings on them,one of the cv boots were kinda toasted.those would probably be the main priority that i got to take care of on the list.thanks for the heads up.
Old Nov 20, 2008 | 12:07 AM
Genetically Gay
only thing bugging me rite now is the beeping sounds coming from seatbelts.i check the fuse but theres no seatbelt fuse??try unplug under seats that didi'nt worked..anyway i can stop beeping sound??
Old Nov 20, 2008 | 03:11 AM
~sp33~'s Avatar
EFB055
If you READ what i wrote then that's exactly what i said. But thanks for trying.
95C0upe
18
Oct 28, 2008 06:30 PM
ck123
Mar 24, 2006 03:51 PM
CereaLand
Feb 12, 2003 08:26 PM
Toda Party
Oct 27, 2002 07:26 AM
Nuts
Jul 2, 2002 08:24 PM
