Need Help Quick with installing lower Timing Gear on D16Z!!!
Old Jul 31, 2002 | 03:22 PM
D-Man's Avatar
Default Need Help Quick with installing lower Timing Gear on D16Z!!!
I'm trying to install the lower timing gear on the crankshaft on a D16Z.My problem is i cant figure out if it had one or two washers for the lower timing gear.I got one washer,its about 2" in diameter and it has 5 oval holes around its center hole,so if this is the only washer,does it go on the crankshaft first,then the timing gear or do you put the timing gear on first and then the washer....if there is two washers,i need to find another one...
[Modified by D-Man, 12:02 AM 8/1/2002]
Old Jul 31, 2002 | 11:08 PM
vhd's Avatar
vhd
Default Re: Need Help Quick with installing lower Timing Gear on D16Z!!! (D-Man)
there is two of the timing belt guides, one goes on the inside and one goes on the out side of the lower timing belt drive gear. the guides are concaved, so make sure you installed it so the it flares out away from the belt.
Old Aug 1, 2002 | 02:46 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Need Help Quick with installing lower Timing Gear on D16Z!!! (vhd)
correct. I have a few from D15 trash motors, they should be the same.
FREE + shipping, about $1-2 total.
ctague@cinci.rr.com
Old Aug 1, 2002 | 06:59 AM
D-Man's Avatar
thanks!!! and thanks mista bone for the offer but i'm sure i got one lying around and i need it by tonight..aug 1st
tobster
Mar 17, 2010 08:20 PM
lude98SH
Nov 5, 2007 06:38 PM
downeyballz
Jun 6, 2005 11:10 AM
fastludeh22
Aug 13, 2003 05:41 PM
