f/s gsr block, trans
ill be in TEXAS for the holiday...
everything will be put on hold until i get back...
txt me at: 715-529-9069
everything is pick up only...
95 gsr block - stock bore - cp pistons 9.0:1 - eagle h beam rods - acl race bearings = $1000
act 6 puck unsprung clutch - 7.5lb fidanza flywheel = $200
bbk intake manifold = $200
bbk throttle body 70mm = $200
pick up everything listed above for $2000 and ill throw in all the following...
oem gsr ecu
oem gsr pistons and rods
oem gsr intake manifold
oem ?gsr? exhaust manifold
axles and halfshaft (b-series into 92-95 civic)
motor mounts with T-bracket (b-series into 92-95 civic)
shift linkage
engine wire harness
universal apexi blow off valve
oem gsr ecu
shift linkage
engine wire harness
