Suspension & Brakes Theory, alignment, spring rates....
Forgot backing plate on front brakes
Old Nov 18, 2008 | 01:30 PM
snobordin8's Avatar
Default Forgot backing plate on front brakes
As the title states, I just changed my girlfriends brakes for her and once I got done, I realized I forgot to put on one of the backing plates for the brake pad. Should I take it back apart to replace this plate? Will it cause premature wear on the brake pads/rotors if I do not? After just doing the brakes, I could probably replace it in about 30 minutes, but if it isn't necessary I do not want to bother with it.
This is on a 2001 Civic if it matters.
Thanks!
Old Nov 18, 2008 | 04:06 PM
hatchling37's Avatar
Are you talking about the shim? If so, it's not going to f anything up, but you might get some brake noise if you didn't lube it properly.
Old Nov 18, 2008 | 04:10 PM
snobordin8's Avatar
Yea, I'm talking about the thin metal plate that goes on the back of the brake pad. She has been complaining about it still squeaking, but I haven't driven it to see if it's the wheel I forgot to put it on.
Old Nov 18, 2008 | 04:11 PM
If it's still squeaking, just might as well take everything apart and properly lube the pads and anti-rattle clips
Old Nov 22, 2008 | 05:02 PM
Evs-One's Avatar
Solbros Owns Me
Chamfer the leading edge of the pads too....you use cheap pads or what?
Old Nov 22, 2008 | 08:06 PM
snobordin8's Avatar
No they're ceramic pads with Brembo Blank rotors. I took them back apart this morning, and found out there were shims behind all 4 pads. Apparently there were 2 shims behind one of the pads, I put it back where it came from and 20 miles later the squeak is still gone. I guess we'll see.
jlowellintegra
Dec 23, 2010 09:46 PM
92ehatch
Mar 23, 2006 07:06 PM
AMG
13
Aug 18, 2004 09:03 AM
Poopie
Jun 25, 2004 07:03 PM
integra0260
Oct 21, 2001 08:09 AM
