Manual tranny wont quit leaking tried everything
Old Nov 18, 2008 | 01:14 PM
jimmy o.'s Avatar
Default Manual tranny wont quit leaking tried everything
Ive got this 94 ex it wont quit leaking manual tran fluid have had both axle seals replaced and new axles. Right after i had it done it still leaks a big puddle in my driveway i had a shop do the work (to fix the leak). what could be the problem?
Old Nov 18, 2008 | 02:58 PM
Sr420Det's Avatar
Might have way to much in there
Old Nov 18, 2008 | 04:02 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The fluid may be over filled. There may be a crack in the trans housing. The axle may have a burr in it where it sits on the lip seal. No matter how many seals you put on it, it will keep chewing them up. The drain bolts may be loose or missing the crush washers.
Old Nov 18, 2008 | 04:06 PM
instructor74's Avatar
might be leaking from the isb seal, and or the sifter seal,or they are damaging them when putting them in
Old Nov 18, 2008 | 04:12 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i bet the seals are damaged or over filled
Old Nov 18, 2008 | 05:15 PM
postman's Avatar
sure its not the rear main
Old Nov 18, 2008 | 06:25 PM
civicxpress's Avatar
case seal? just a thought
Old Nov 20, 2008 | 12:53 PM
jimmy o.'s Avatar
Ok it was just the drain plug was loose i dont know how it happened oh well at least its fixed now
Old Nov 20, 2008 | 02:10 PM
97Ej6mike's Avatar
Input shaft bearing leaking out the flywheel housing?
THats a situation you DONT want.
Gabe87CRX
Transmission & Drivetrain
May 27, 2010 09:59 AM
landon.alder
17
Oct 21, 2009 04:56 PM
kdsmonitor
Mar 7, 2009 04:00 PM
Scud
Feb 23, 2006 03:44 PM
ewaugh
Jan 24, 2005 07:03 PM
