Vtec at 6 grand...
Old Nov 18, 2008 | 12:29 PM
mr2passat801's Avatar
Default Vtec at 6 grand...
My vtec doesn't engage until six grand. Everything runs fine though. What could be the cause of this?
Old Nov 18, 2008 | 12:42 PM
90_EX_Civic's Avatar
is it chipped??
Old Nov 18, 2008 | 01:04 PM
keepinitrehaal's Avatar
bump
Old Nov 18, 2008 | 01:43 PM
neardon's Avatar
I'm a Jackass
U be rockin da b18c1 it haz da special kick a vtec @ 6000, if u close 2 ne carz itll knock em off da road.
Old Nov 18, 2008 | 03:36 PM
Mfoehrkolb's Avatar
--- I am using a CTR ECU. My car also is engaging around 6k to 6.3krpms. IDK why but it's quite annoying. I cleaned my vtec solenoid, it's fresh oil up to proper level. I'm not quite sure what else would be making it do this.
Old Nov 18, 2008 | 03:48 PM
Jayman_Gsr's Avatar
My Stock gsr kicked in at 6k, you may need to chip the ECU and reprogram it to whatever you want. (I converted to OBDI and using crome I have mine set to `5k with IAB's set at the stock 4.5k sounds NICE) That should fix your prob. if not then you def have a prob, but if vtec works now then there shouldn't be a prob...(Confusing?!?!? maybe :D)
Old Nov 18, 2008 | 04:50 PM
majinsoftware's Avatar
The ECU controls the vtec point, Cleaning and changing oil wont affect it.
So you can eather get a vtec controler.(Not the best option because it doesnt change the fuel maps)
Or get another ecu/or get it reporgramed.
You should defently get it set on a dyno so you know the best place to put it.
Old Nov 19, 2008 | 02:36 AM
dc2kidd's Avatar
in reality,the ecu's that you use DO effect where and how your vtec will engage depending on the program. a itr p73 has vtec engagement i believe at 5600 or 6000.. cant remember right now, but comparing it to a P2T from a 99-00 SI or P72 from a gsr that both engage at 5500 it honestly depends on what program is being run in the ecu..
Old Nov 19, 2008 | 04:32 AM
Dogginator's Avatar
Daisy... Daisy...
Do not post untrue information. A stock P72 has a VTEC point of 4400 RPM and an IAB of ~5750 RPM. OP, are you hearing the IAB on a B18C1 and mistaking it for VTEC? A stock B18C1 has a very quiet VTEC engagement.
Old Nov 19, 2008 | 05:41 AM
JDM 98 GSR's Avatar
im using an ITR computer and mine hits at 6k or 6.3k also and i didnt everything you did too as far as cleaning, fresh oil and everything
Old Nov 19, 2008 | 06:13 AM
Ok, so my motor is fully built with low compression pistons.. 9:1. Not turbo yet.
My ecu has a chip with the stock GSR honda factory map on it. My o2 sensor just busted. So I have a CEL. And I can very clearly hear vtec kick at 6000. Not sure if my low compression would affect the map in any way... And also what is IAB???
Did you mean IDB? Ha, just kidding...
Old Nov 19, 2008 | 06:23 AM
AWD Terror's Avatar
Quote from T-I.net article:
"Coupled with VTEC, you can see the GS-R engine has three stages of operation.
Stage 1 (0-4400 RPM): Low-lift cam lobe and long intake runners.
Stage 2 (4400-5800 RPM): High-lift cam lobe and long intake runners.
Stage 3 (5800+ RPM): High-lift cam lobe and short intake runners.
This three stage system is how the GS-R is able to keep a flat torque curve. Changing to a single-stage intake manifold such as the Skunk2 would amplify the cam lobe change and you would see a double hump torque curve similar to the Type R.
Most people confuse the opening of the short intake runners as VTEC engagement because of the dramatic change in sound. It is hard to hear VTEC at 4400 RPM using the dual-stage intake manifold because the long runners restrict flow volume to the engine in order to maintain flow velocity. So for anyone that says VTEC on their GS-R is engaging at 5800 RPM tell them their ears are not engine tuning devices."
Edit: So apparently your ears are not engine tuning devices.
Old Nov 19, 2008 | 06:33 AM
Jayman_Gsr's Avatar
Well I had a stock p72 OBD2a ecu in my 97 and the first stage is low cam and short runners to give a good tq response down low, then at ~4500 the second stage kicks in which is low cam with IAB's open (longer runner for more top end power), and third stage is vtec engaging at `6k with the IAB's still open. I hope im not giving false info on this but this is my understanding of the GSR mani. Im not trying to contradict anyone so please don't bash, JUST CORRECT ME IF I AM WRONG! This is how it was when I had my stock comp in. I am now running a P06 chipped and converted for vtec and IAB. However I set my Vtec point at 4800ish in crome and my IAB's around 4500ish. (I have to wire in a relay still to get the IAB's the correct signal aka OBD2 is Pos and OBD1 is Neg. But right now my IAB's arent activating.
Old Nov 19, 2008 | 06:54 AM
spoolie's Avatar
wow..the fail/mis-information in this thread is strong..
Old Nov 19, 2008 | 06:58 AM
Jayman_Gsr's Avatar
Im getting rid of mine soon anyways....
Old Nov 19, 2008 | 08:13 AM
b17rider's Avatar
maybe a 92-93 gsr ecu? is your motor odb1? stock vtec engament is 5700 on these
Old Nov 19, 2008 | 08:24 AM
neardon's Avatar
I'm a Jackass
I dont think h-t would be the same without it.
Old Nov 19, 2008 | 10:07 AM
racebum's Avatar
as stated above, the stock GSR vtec is 4400
stock ITR is 5700
vtec is seamless on the GSR and a little harder hitting on the ITR
Old Nov 19, 2008 | 12:55 PM
mouab18c1's Avatar
im confused? so does a stock p72 vtec kick in at 5500rpm or what? ahahah and what is IAB? i feel retarded asking that question....
Old Nov 19, 2008 | 01:08 PM
neardon's Avatar
I'm a Jackass
No, stock is 4400. GSR intake manifolds have an IAB in them that allow them to produce steady power down in the low rpms and up high. AWD Terror described it well read his post.
Old Nov 19, 2008 | 03:21 PM
vladd's Avatar
it's amazing how many people here don't know how to read.
Old Nov 19, 2008 | 03:37 PM
95 integra's Avatar
Half way down before we get a decent post....nice. That and I love how people talk about their GSR and then 3 pages later mention that it has a different ecu/chip/program/vafc/flip switch for the vtec solenoid that changes their vtec point. vtec = 4400
IAB = Intake Air Bypass = Secondaries = flapper doors = dual-stage intake manifold...all the same ****.
Old Nov 19, 2008 | 08:26 PM
mouab18c1's Avatar
hahaha its amazing how people dont know how to provide the correct answer to the question....
Old Nov 19, 2008 | 08:27 PM
mouab18c1's Avatar
thanks for answering the question
Old Nov 19, 2008 | 08:33 PM
vladd's Avatar
the answer to your question was already posted. seriously, read through it. it's there, i quoted it.
