is it okay to mix leaded and unleaded fuel?
Old Nov 18, 2008 | 12:09 PM
Dave_Dc2's Avatar
Default is it okay to mix leaded and unleaded fuel?
i know with time it will mess up the o2 sensors and the cat but other than that is there a problem?? all help is appreciated thank you
Old Nov 18, 2008 | 12:15 PM
Dogginator's Avatar
Daisy... Daisy...
They will physically mix. What is your intent with this concoction?
Old Nov 19, 2008 | 08:29 AM
Dave_Dc2's Avatar
well my motors comp is 12:1 and the Highest fuel in my area is 91 so what I wanted to do was mix 91 and 110 at a 5:1 ratio averaging it out to about 94 so the question was is it okay to mix unleaded pump fuel and 110 vp leaded?
Old Nov 19, 2008 | 08:39 AM
mrdeadman's Avatar
They let me pick
12:1 really isn't that high to necessitate using higher than 91 octane.
Old Nov 19, 2008 | 08:43 AM
4g63powered's Avatar
:imwithstupid:
91 will be fine.
Old Nov 19, 2008 | 09:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If it detonates on 91 octane, you either need to get it tuned, or get it tuned better.
Old Nov 19, 2008 | 12:11 PM
Dave_Dc2's Avatar
i know it can be tuned on 91 but that will require to retard the timing so only so much, so im trying to go a little higher to reduce the retarding of the timing..
Old Nov 19, 2008 | 01:46 PM
dc4_wHORE's Avatar
Soldering Iron Wizardry
why not run vp motorsport 109?
Old Nov 19, 2008 | 02:53 PM
Dartanian's Avatar
Too bad you are in CA. E85 would be a perfect remedy of this issue.
Old Nov 19, 2008 | 03:43 PM
TunerN00b's Avatar
Not with time. A single tank of leaded will kill the cat, which will trigger a CEL on an OBD2 car since the 2nd O2 will read rich (it will know you killed the cat). Your valves will love you though...
Old Nov 19, 2008 | 04:14 PM
mrdeadman's Avatar
They let me pick
What he meant is that you are not tuned well if it detonates on 91. 12:1 compression is not high enough to cause detonation with 91. To give you an example my dirt bike has 13.5:1 compression and does not detonate running 91 octane.
RonMexic07
Apr 24, 2006 09:19 PM
Terrible One
14
May 10, 2005 09:29 AM
srehmat02
Sep 17, 2004 02:16 PM
Tofurky
Aug 26, 2003 11:49 PM
GapxGuy
Dec 30, 2002 04:03 PM
