Turns over no start
Old Nov 18, 2008 | 12:01 PM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Turns over no start
I got a 95 EG hatch CX with a D15b (i believe). I had an LS in my car but blew my motor and needed something to drive so i but the single back in it. I had a viper alarm system installed when I had the LS
now i got everthing hooked up and tried to start it. Cycled the key a couple time to get fuel pressure and i could hear the fuel pump. It would turn over but not start. 1 time it sounded like it was going to start and now nothing. i tried replacing the coil and button.
now when i cycle the key i dont hear the fuel pump.
I called the people who installed my alarm system and they say they wire it through the ignition system and kill the starter.
I thought maybe it could still be my alarm system. Im going to disconnect my alarm system tonight.
do you guy have ne other things i could look at?
Old Nov 18, 2008 | 01:45 PM
sol2hatch's Avatar
Usually the alarm would cut off the starter, and it would not turn over at all. Could still be your alarm, but not likely.
Check for spark. If your fuel pump is not priming, find out why.
Where did you get the engine from, and do you know for a fact it was running before you got it?
Check to see if your getting compression, and check your timing.
Old Nov 18, 2008 | 03:21 PM
hondateg10's Avatar
yes i know the motor was running before it was my stock motor. i am getting no spark.
Old Nov 18, 2008 | 03:31 PM
sol2hatch's Avatar
your not getting spark at all? Start checking your wiring, dizzy, cap, etc.
You are running the right computer right? not same from your other engine?
Old Nov 18, 2008 | 03:45 PM
hondateg10's Avatar
i replaced the cap and coil. got the right computer in also
Old Nov 18, 2008 | 03:48 PM
hondateg10's Avatar
i also noticed that when i have the key in on position the eng light isnt on. but when i start to turn the key the eng light lights up just a little but no bright like normal
Old Nov 19, 2008 | 06:42 AM
hondateg10's Avatar
bump
Old Nov 20, 2008 | 12:17 PM
hondateg10's Avatar
still need help guys
Old Nov 20, 2008 | 03:15 PM
EGTurboB16's Avatar
You really only need 3 things to make your engine turn over; Fuel, Compression, and Igniter. If your engine is turning over, your starter should be fine. I would also check all your fuses and relays as they control your fuel regulation, you may have blown a fuse during the swap or when you replaced the coil. Just because your motor is turning over, doesn't mean your spark plugs can't be fouled, so after you check the fuel, I would pull the spark plugs, it's easy enough to do. Also try to run a resistance check on your spark plug wires. The last thing I would check is the compression in the cylinders. See if you can find someone to do a compression check or a cylinder leak down test.
Old Nov 20, 2008 | 04:18 PM
wrenchez81's Avatar
doooooooooooooooooood!!! check ur grounds!!!!!!!!!!!!!!!!!!!!
Old Nov 20, 2008 | 05:06 PM
nemesis25's Avatar
Try another ECU. I had the same issue not too long ago. I thought it was the main relay, by the way you should check this too by jumping the no.5 and no.7 terminals. But it turned to be my ECU.
Old Nov 20, 2008 | 05:31 PM
mr.sky's Avatar
Check your grounds.
Old Nov 22, 2008 | 12:37 PM
hondateg10's Avatar
i checked all my grounds and fuse all ok. someone told me to check my relay. when i turned the key over i didn't hear a click from the relay. my questions are should i hear a click from the relay? and if so could this be my problem?
Dead CIVIC
Audio / Security / Video
Nov 28, 2012 08:21 PM
tvman
Dec 8, 2008 05:44 PM
dsh7941
Apr 1, 2007 03:36 PM
J_Bones
Dec 5, 2004 05:53 AM
aquarius
Jul 15, 2004 07:53 AM
