Will a 1998 Civic Si INTAKE fit on a D16Y7?
Quick question:
Buying stock intake for my D16Y7, will one pulled from a 1998 SI fit? Not sure if this is the American Si or Ex, will either fit?
Yes? No?
Yes? No?
doubt it due to the design the IM is designed on the d16y7 is WAY diff from the Si model in Canada, Ex in the US. Just either get a y8 head and then youll kill 2 birds with one stone, ull be able to have ur Si intake and vtec [with the proper wiring]
hope that helps
hope that helps
no a SI's intake manifold will not fit. different motor series as it is a b-series. you can swap out manifolds from other d-series engines though. the d16y8 IM being popular among the d-series.
He's from Canada saying it's a 1998 Si. So it should obviously be our (US) EX. Either way, it's still a no. Unless you do some Home Depot type thing.
*EDIT: he's talking about INTAKES okay nvm. just get yourself a d16y8 IM and youll be good.
The OP is in Canada, the Si is refering to has a D16Y8 and is pretty much a rebadged EX coupe. And no it wont work, due to the fact the Y7 intakes point straight up and the Y8s are sideways. You could however get an automatic Y8 manifold and then use the intake, its important to use an automatic Y8 manifold btw, even if its going on a manual Y7 otherwise you will have IACV issues.
OptimusPrimeX
Jul 7, 2002 06:06 PM
