E-brake light on my display cluster stays on when really cold outside
Old Nov 18, 2008 | 08:12 AM
Lovemy99Lude's Avatar
Icon2 E-brake light on my display cluster stays on when really cold outside
So this is going to be my first winter with my Lude and I come to find out that my e-brake light in my display cluster stays on and I cant figure out why. It only comes on after it reaches a certain temperature. Would anyone know whats going on and how to fix it???
Old Nov 18, 2008 | 08:20 AM
red_crx's Avatar
yout e-brake cables might need some adjusting...they might be a little loose; OR you might want to check you brake fluid level
Old Nov 18, 2008 | 08:34 AM
firaga21's Avatar
Yea, what he said plus your floater might be sticking...
Old Nov 18, 2008 | 08:36 AM
gstrudler's Avatar
Yeah, you're brake fluid level is a little low. When it's really cold the fluid contracts, dropping the overall volume and causing the warning light to come on. Just top it off and you should be good to go
Old Nov 18, 2008 | 09:09 AM
Thanks you guys! I'll do this and see what happens.
Old Nov 18, 2008 | 03:31 PM
Kronn 98SH's Avatar
Mine does the exact same thing, only during really cold weather. My fluid is full, so I think we need some adjusting
Old Nov 18, 2008 | 05:13 PM
jcball3r's Avatar
I had this problem before, I just took off the brake fluid cap, cleaned it, and the light was gone. The floater is probably your problem if you have the correct amount of fluid.
Old Nov 19, 2008 | 01:05 AM
Honda4Life.'s Avatar
There is a TSB from Honda on this and it affects Accord, Civic's and CR-V's as well.
Here is the info for ya.
Service Bulletin 03-078
Affects
96-00 Civic
97-01 CRV
97-01 Prelude
98-02 Accord
Parts need to fix the problem.
Filter part #46666-S04-J02
Float part #46662-S84-999
Its should be under $10.00 for the 2 parts from the dealer.
Hope that helps ya all out.
Old Nov 19, 2008 | 05:40 AM
Thanks!
AlpHaRitEr
12
Jun 2, 2015 07:30 PM
motormike40
Nov 22, 2006 09:41 PM
LunchboxZT
Sep 8, 2006 01:22 PM
AFAccord
Nov 1, 2005 02:25 PM
.water
Jun 11, 2005 12:06 PM
