Did a mini me, switched ecu and now i get a cel code HELP!!
Old Jul 31, 2002 | 01:31 PM
RoaringTurtle's Avatar
New User
Default Did a mini me, switched ecu and now i get a cel code HELP!!
Recently I did a mini me swap on my d16y7 block
Everything runs great
I just bought a vtec ecu
and I hooked up the vtec
plugged the ecu in
and now I get a cel code
I saw a post a day or so ago about if the vtec isnt hooked up properly u get a cel code
now i ran a switch to my vtec solenoid and tested it out, it clicks and everything,
I double checked the connections to the ecu, everything is fine
I tried checking the cel code and it doesnt blink, it just stays lit so i dont know what is wrong
On the vtec pressure sensor, does one wire go to ground and the other to the vtec pressure pin on the ecu?
and does it matter which wire goes to ground
i think it might be the ecu, but im not sure
also it could be that i hooked up the vtec to the wrong pins on the ecu
if someone has a diagram to show me which pins im supposed to hook it up to, i could double check it
thanks in advance
Old Jul 31, 2002 | 02:34 PM
Jackson's Avatar
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (RoaringTurtle)
Step 1.
Step 2. Check your code.
...off of Katman's site.
[Modified by Jackson, 3:35 PM 7/31/2002]
Old Jul 31, 2002 | 03:34 PM
New User
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (Jackson)
yeah i said i checked the code
it doesnt blink at all
just stays lit
and the car doesnt run very well
Old Jul 31, 2002 | 03:41 PM
cyrk007's Avatar
im dlric.. he had the same problem for a while with his
Old Jul 31, 2002 | 03:54 PM
Jackson's Avatar
just stays lit
Old Jul 31, 2002 | 04:43 PM
New User
sorry about that
what i meant was it runs great with the old ecu, the one with no vtec
but when i plug the vtec ecu in
it gives me a cel code (which doesnt blink when i try to check it, just stays lit)
New User
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (cyrk007)
thanks
ill do that
Old Jul 31, 2002 | 06:13 PM
98slvrcx's Avatar
So you used to have a y7 ecu non vtec. You did a minime Y8 head on Y7 block . Then you hooked up the VTEC ECU. Was it a one from Y8? Also from what you typed above it sounds like you didnt kook up your VTEC to your ECU. If this is it , run the wire vtec wire into your ECU. All your problems should be fixed.
Old Jul 31, 2002 | 07:53 PM
New User
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (98slvrcx)
i ran the vtec wire
i also ran the vtec pressure wire to the vtec ecu
i double checked all the connections with a meter
but i get a cel code
even when i unhook it i get a cel code
the cel code doesnt blink when i try to check it
just stays on
i have no idea what it is
but im suspecting its the ecu
Old Aug 1, 2002 | 07:52 AM
Jackson's Avatar
Usually when the light stays on, it means the ecu is defective. Try a different one if you are confident on your wiring.
Old Aug 1, 2002 | 01:19 PM
New User
yeah thats what i figured
thanks for the help
Old Aug 3, 2002 | 03:31 AM
RR98DX's Avatar
you put on a Z6 head or a Y8? i heard if you run the Z6 you will be off on timing unless you run a cam gear. anyone back me up on this?
Old Aug 3, 2002 | 08:03 AM
fixhondas's Avatar
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (RR98DX)
what year is your civic body and what year is your ECU? There are two OBD2 harnesses in these cars, depending on year/model. Some are NOT plug and play.
Old Aug 3, 2002 | 01:21 PM
New User
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (fixhondas)
i have a 97 dx hatchback
put a z6 head on it
and yes i have an adjustable cam gear, my cam timing is fine
i put a 96 ex ecu in it, it plugs in fine
and i know the 99-00 ex ecu's are different
Old Aug 3, 2002 | 02:33 PM
RR98DX's Avatar
then why post if you know everything?
Old Aug 3, 2002 | 04:40 PM
LD_EGSICK's Avatar
ummm..... this might help...make sure u did every thing right.....
http://crx.honda-perf.org/articles/z6swap/z6swap.html
Old Aug 3, 2002 | 05:15 PM
.nate's Avatar
Default Re: Did a mini me, switched ecu and now i get a cel code HELP!! (mysiqu)
If it stays lit with the plug properly jumpered, the ECU is defective.
Old Aug 5, 2002 | 01:04 PM
New User
im not saying i know everything
i just knew those points
and thats why im still stumped
i should have explained it better in my first post
but thanks for the help guys
im gonna try and get a new ecu
and see if that works
Old Aug 5, 2002 | 01:17 PM
Dr. EKology's Avatar
have you changed anything on your car other than you mini-me?? Lets get some recent pics!!
Metal Head
Sep 28, 2006 11:39 PM
Jose-aka-Pedro
May 21, 2006 06:41 PM
TURBO DC2
Jul 17, 2005 06:30 AM
WhiteDSM520
Jan 24, 2005 10:34 AM
EGh22aEG
Mar 18, 2002 04:18 PM
